Ga door naar hoofdinhoud
Creative Nomad Jukebox Zen Auxiliary Jack Input placement
Wat je nodig hebt
  1. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: stap 1, afbeelding 1 van 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: stap 1, afbeelding 2 van 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: stap 1, afbeelding 3 van 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: stap 2, afbeelding 1 van 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: stap 2, afbeelding 2 van 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Screen Cover: stap 3, afbeelding 1 van 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Auxiliary Port: stap 4, afbeelding 1 van 1
    • Using a soldering iron, melt the solder in order to free the auxiliary jack.
    • Hoe moet je (de-)solderen? Use soldering gun with care as it becomes extremely hot and can cause burns
  5. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: stap 5, afbeelding 1 van 1
    • Using the plastic opening tool, gently pry up the other side of the auxiliary jack motherboard.
  6. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: stap 6, afbeelding 1 van 1
    • Using the plastic pulling tool, pull the plastic housing of the device out of the way in order to wiggle the the auxiliary jack motherboard free.
Conclusie
Bradley McHugh
101 Reputatie
1 Handleiding geschreven
IUPUI, Team S4-G5, Baechle Spring 2017 Lid van IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Leden
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 582
