Ga door naar hoofdinhoud
Creating a Buttonhole Using a Sewing Machine
Wat je nodig hebt
  1. Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: stap 1, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine, Creating a Buttonhole Using a Sewing Machine: stap 1, afbeelding 2 van 2
    • Select your buttonhole foot. Buttonhole feet can vary in appearance, so check you manual.
    • Thread the buttonhole foot by sliding the thread through the diagonal slit into the center hole.
  2. Creating a Buttonhole Using a Sewing Machine: stap 2, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 2, afbeelding 2 van 2
    • Mark where you would like the top and bottom of the buttonhole to be with tailor's chalk.
    • You can measure your button if you aren't sure.
    • Align the sewing machine at the upper left corner of the buttonhole.
  3. Creating a Buttonhole Using a Sewing Machine: stap 3, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 3, afbeelding 2 van 2
  4. Creating a Buttonhole Using a Sewing Machine: stap 4, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 4, afbeelding 2 van 2
    • Set your stitch length dial to nearly zero, this will create a satin stitch. The usual stitch length is around the 2.5.
  5. Creating a Buttonhole Using a Sewing Machine: stap 5, afbeelding 1 van 3 Creating a Buttonhole Using a Sewing Machine: stap 5, afbeelding 2 van 3 Creating a Buttonhole Using a Sewing Machine: stap 5, afbeelding 3 van 3
    • Set your button hole dial to one. If you have an electronic sewing machine, refer to your manual.
    • Every time you adjust this dial, your needle will move. That's okay; it's supposed to do that.
    • Start sewing. Sew to your second line.
  6. Creating a Buttonhole Using a Sewing Machine: stap 6, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 6, afbeelding 2 van 2
    • Set your button hole dial to two.
    • Sew the bar tack at the bottom of the buttonhole.
    • Setting the button hole dial to two tells your sewing machine what to do, all you need to do is sew a few stitches to create the bar tack.
  7. Creating a Buttonhole Using a Sewing Machine: stap 7, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 7, afbeelding 2 van 2
    • Set your buttonhole dial to three.
    • Sew up the second side of your buttonhole, stopping at your top mark.
  8. Creating a Buttonhole Using a Sewing Machine: stap 8, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 8, afbeelding 2 van 2
    • Set your buttonhole dial to four.
    • Sew the top bar tack at the top of the buttonhole.
  9. Creating a Buttonhole Using a Sewing Machine: stap 9, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 9, afbeelding 2 van 2
    • Set your buttonhole dial to five.
    • This setting backstitches to hold the thread in place. Sew a few more stitches, which will finish the buttonhole.
  10. Creating a Buttonhole Using a Sewing Machine: stap 10, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 10, afbeelding 2 van 2
    • Clip the threads, freeing the fabric from the machine.
    • Clip any extra loose threads.
  11. Creating a Buttonhole Using a Sewing Machine: stap 11, afbeelding 1 van 2 Creating a Buttonhole Using a Sewing Machine: stap 11, afbeelding 2 van 2
    • Use a hobby knife to cut open the buttonhole.
    • Be careful not to cut through the stitching, you only want to cut the fabric between the rows of stitching.
Eindstreep
4 andere personen hebben deze handleiding voltooid.
Brittany McCrigler
89.017 Reputatie
131 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
2 opmerkingen
I got up to position (!) 2 ok, then when I tried to go back up on position 3 it didn't work and just chewed up my fabric. Is it supposed to go backwards, or are you supposed to turn the fabric around? Did I do something wrong?
Holly - Antwoord
The same thing happened to me when I first tried this too, Holly.
I discovered that I was over-stitching position 2.
Now, I do a maximum 3 stitches only, before I go on to position 3 and everything works beautifully. I don’t have to turn the fabric around - position 3 stitches in reverse, and I finish off with a couple of stitches in position 2, to top off the button-hole.
I hope this helps!
Roszarie - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 60
Altijd: 27,484
