Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
In order for the Crayola Crayon Maker to melt crayon pieces and create new whole crayons, the light bulb needs to be in good working order. To replace a burned out bulb, all that is needed is a small Phillips screwdriver and a colorless 60-watt candelabra light bulb with a small base.
Wat je nodig hebt
Press the green arm away from the melting tray. Remove the melting tray.
Pop the metal arms out of the green pivot support.
Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Één andere persoon heeft deze handleiding voltooid.
