Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Press the green arm away from the melting tray. Remove the melting tray.
Pop the metal arms out of the green pivot support.
Remove the 2 screws (.75cm in length) currently securing the metal melting tray with a Phillips #2 screwdriver.
The light bulb should now be revealed. Unscrew the burned out bulb and replace with a new bulb.
Één andere persoon heeft deze handleiding voltooid.
