Ga door naar hoofdinhoud
Craig Electronics CMP773 Screen Replacement
Wat je nodig hebt
    1. Craig Electronics CMP773 Screen Replacement, Screen: stap 1, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement, Screen: stap 1, afbeelding 2 van 2
      • Remove two screws on the charging port side of the tablet using the Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Craig Electronics CMP773 Screen Replacement: stap 2, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 2, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 2, afbeelding 3 van 3
      • Insert a plastic opening tool between the screen and the back of the tablet.
      • Insert another opening tool along the same side of the tablet and pry them in opposite directions until the casing pops.
      • Once roughly half of the case has been unlatched, it can be removed by hand.
      Vraag FixBot
      Voeg opmerking toe
    3. Craig Electronics CMP773 Screen Replacement: stap 3, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 3, afbeelding 2 van 2
      • Use the spudger to gently pry the camera from the casing.
      Vraag FixBot
      Voeg opmerking toe
    4. Craig Electronics CMP773 Screen Replacement: stap 4, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 4, afbeelding 2 van 2
      • Using your finger, remove the clamp that connects the screen power rib to the motherboard.
      • Using needle nose pliers, remove the ribbon.
      Vraag FixBot
      Voeg opmerking toe
    5. Craig Electronics CMP773 Screen Replacement: stap 5, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 5, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 5, afbeelding 3 van 3
      • Remove the second screen power connection from the motherboard using the same procedure as step 4.
      Vraag FixBot
      Voeg opmerking toe
    6. Craig Electronics CMP773 Screen Replacement: stap 6, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 6, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 6, afbeelding 3 van 3
      • Remove four screws from the motherboard using the Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    7. Craig Electronics CMP773 Screen Replacement: stap 7, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 7, afbeelding 2 van 2
      • Remove a single screw from the speaker using the Phillips #00 screwdriver.
      • Pry up on the locking tabs with the flat spudger.
      Vraag FixBot
      Voeg opmerking toe
    8. Craig Electronics CMP773 Screen Replacement: stap 8, afbeelding 1 van 1
      • Using needle nose pliers, remove the ground wire from the casing.
      Vraag FixBot
      Voeg opmerking toe
    9. Craig Electronics CMP773 Screen Replacement: stap 9, afbeelding 1 van 1
      • Using the plastic opening tool, remove the battery.
      Vraag FixBot
      Voeg opmerking toe
    10. Craig Electronics CMP773 Screen Replacement: stap 10, afbeelding 1 van 2 Craig Electronics CMP773 Screen Replacement: stap 10, afbeelding 2 van 2
      • With all screws and components removed, gently remove the motherboard from the casing.
      Vraag FixBot
      Voeg opmerking toe
    11. Craig Electronics CMP773 Screen Replacement: stap 11, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 11, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 11, afbeelding 3 van 3
      • Insert the spudger in between the screen and case. Work your way around the outside of the screen.
      Vraag FixBot
      Voeg opmerking toe
    12. Craig Electronics CMP773 Screen Replacement: stap 12, afbeelding 1 van 3 Craig Electronics CMP773 Screen Replacement: stap 12, afbeelding 2 van 3 Craig Electronics CMP773 Screen Replacement: stap 12, afbeelding 3 van 3
      • Grasp the exposed screen corner and gently separate the screen from the housing.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Justin mersch
205 Reputatie
1 Handleiding geschreven
IUPUI, Team S3-G4, Harley Fall 2019 Lid van IUPUI, Team S3-G4, Harley Fall 2019
IUPUI-HARLEY-F19S3G4
4 Leden
3 handleidingen geschreven
1Gids Commentaar
What kind of battery does this device specifically use
Kris Miller - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 480
