Ga door naar hoofdinhoud
Cr-48 Chromebook Network Card Replacement
Wat je nodig hebt
  1. Cr-48 Chromebook Network Card Replacement, Battery: stap 1, afbeelding 1 van 3 Cr-48 Chromebook Network Card Replacement, Battery: stap 1, afbeelding 2 van 3 Cr-48 Chromebook Network Card Replacement, Battery: stap 1, afbeelding 3 van 3
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
    Vraag FixBot
    Voeg opmerking toe
  2. Cr-48 Chromebook Network Card Replacement, Bottom Casing: stap 2, afbeelding 1 van 2 Cr-48 Chromebook Network Card Replacement, Bottom Casing: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
    Vraag FixBot
    Voeg opmerking toe
  3. Cr-48 Chromebook Network Card Replacement: stap 3, afbeelding 1 van 3 Cr-48 Chromebook Network Card Replacement: stap 3, afbeelding 2 van 3 Cr-48 Chromebook Network Card Replacement: stap 3, afbeelding 3 van 3
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
    Vraag FixBot
    Voeg opmerking toe
  4. Cr-48 Chromebook Network Card Replacement: stap 4, afbeelding 1 van 3 Cr-48 Chromebook Network Card Replacement: stap 4, afbeelding 2 van 3 Cr-48 Chromebook Network Card Replacement: stap 4, afbeelding 3 van 3
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
    Vraag FixBot
    Voeg opmerking toe
  5. Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: stap 5, afbeelding 1 van 3 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: stap 5, afbeelding 2 van 3 Cr-48 Chromebook Network Card Replacement, Identify the Network Card and Remove the Connectors: stap 5, afbeelding 3 van 3
    • With the lower case removed, look for the network card. It’s typically located in the corner near one of the USB ports.
    • Use tweezers or forceps to carefully lift off the wire connectors attached to the network card.
    • Take note of which wire went to which terminal (e.g., left vs. right).
    Vraag FixBot
    Voeg opmerking toe
  6. Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: stap 6, afbeelding 1 van 3 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: stap 6, afbeelding 2 van 3 Cr-48 Chromebook Network Card Replacement, Unscrew and Remove Network Card: stap 6, afbeelding 3 van 3
    • Remove the single 3 mm screw securing the network card to the board.
    • Once the screw is out, the card should pivot upward slightly (“pop up”).
    • Gently pull the network card out of its socket at an angle and remove it completely.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an E-Waste certified recycler.
Robert McLaughlin
471 Reputatie
3 handleidingen geschreven
CSU Fullerton, Team 2-2, Bruce Fall 2014 Lid van CSU Fullerton, Team 2-2, Bruce Fall 2014
CSUF-BRUCE-F14S2G2
3 Leden
10 handleidingen geschreven
1Gids Commentaar
The card identified in the pictures is not a combined Wi-Fi / Cellular card. It is just a 3G cellular card; the WiFi card is the other card tucked under the flat ribbon next to the card pictured in this guide
Jorge Gomes - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 29
Altijd: 1,463
