Ga door naar hoofdinhoud
Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement
Wat je nodig hebt
  1. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Glide Pads: stap 1, afbeelding 1 van 2 Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Glide Pads: stap 1, afbeelding 2 van 2
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Use the heat gun on the bottom of the mouse to loosen the glue on the pads.
    • Repeat this step with the other glide pads.
  2. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement, Mouse Nano-Switches: stap 2, afbeelding 1 van 1
    • Remove the two screws from the bottom of the mouse using a T5 Torx screwdriver.
  3. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: stap 3, afbeelding 1 van 1
    • Gently pry open the mouse shell using an iFixit opening tool.
    • Be careful not to force anything or use excessive force, as you may damage the components inside the mouse.
  4. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: stap 4, afbeelding 1 van 1
    • Use an iFixit opening tool to gently pry up the right and left click buttons on the top cover of the mouse until they pop out of place.
    • Be careful not to damage the wiring harnesses that connect the buttons to the PCB.
  5. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: stap 5, afbeelding 1 van 1
    • Use an iFixit opening tool to gently lift the top cover from the mouse body.
    • Be careful not to damage the wires connecting the cover to the mouse PCB.
  6. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: stap 6, afbeelding 1 van 1
    • Using a plastic opening tool, gently pry up the side button assemblies until they pop out of place.
  7. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: stap 7, afbeelding 1 van 1
    • Remove the screws that hold the circuit board in place using a Phillips #0 screwdriver.
    • Gently lift the PCB and set it aside.
  8. Corsair Dark Core RGB PRO SE Mouse Nano-Switches Replacement: stap 8, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • With the nano-switches now exposed, use a soldering iron to melt the solder holding the old switches in place.
    • Use tweezers to carefully remove the old switches and desolder any remaining solder.
Conclusie
Enzo Mello e Silva
145 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 57
Altijd: 522
