Ga door naar hoofdinhoud
Corsair Dark Core RGB PRO SE Battery Replacement
Wat je nodig hebt
  1. Corsair Dark Core RGB PRO SE Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Corsair Dark Core RGB PRO SE Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Cover the sensor on the bottom of the mouse with your thumb so it doesn't get damaged.
    • Apply heat with a heat gun or blow dryer to the glide pad near your palm.
    • Carefully remove the glide pad with a spudger.
    • Remove the two screws from beneath the glide pad using a T5 Torx screwdriver.
  2. Corsair Dark Core RGB PRO SE Battery Replacement: stap 2, afbeelding 1 van 3 Corsair Dark Core RGB PRO SE Battery Replacement: stap 2, afbeelding 2 van 3 Corsair Dark Core RGB PRO SE Battery Replacement: stap 2, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the palm rest by pulling it outwards.
    • Pull up where the latches are.
    • Take your time and work around the area to avoid snapping the plastic latches
    • Remove the top buttons by using tweezers and pushing the tabs.
  3. Corsair Dark Core RGB PRO SE Battery Replacement: stap 3, afbeelding 1 van 3 Corsair Dark Core RGB PRO SE Battery Replacement: stap 3, afbeelding 2 van 3 Corsair Dark Core RGB PRO SE Battery Replacement: stap 3, afbeelding 3 van 3
    • Remove the two screws that were underneath the left and right buttons using a Phillips #00 screwdriver.
    • Place the spudger in between the shell and the bottom of the mouse, releasing the latch.
    • Do not try to remove the top shell by pulling it up as it might break the latch.
    • Remove the six screws using a Phillips #00 screwdriver.
  4. Corsair Dark Core RGB PRO SE Battery Replacement: stap 4, afbeelding 1 van 3 Corsair Dark Core RGB PRO SE Battery Replacement: stap 4, afbeelding 2 van 3 Corsair Dark Core RGB PRO SE Battery Replacement: stap 4, afbeelding 3 van 3
    • Remove the circuit board by pushing the two latches holding it in place in opposite directions.
    • Unplug the ribbon cable by pushing the black connector holding it in place.
    • Disconnect the battery cord by pulling it up.
  5. Corsair Dark Core RGB PRO SE Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery with a spudger or your fingers.
Conclusie
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Where can I buy a spare battery? I don't see them in stores.
Ilya - Antwoord
I found some models that are compatible on Aliexpress
carlus -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 44
Afgelopen 30 dagen: 205
Altijd: 2,818
