Ga door naar hoofdinhoud
Contour Roam2 Mounting Piece Replacement
Wat je nodig hebt
    1. Contour Roam2 Mounting Piece Replacement, Record Slider: stap 1, afbeelding 1 van 1
      • Using the phillips head screwdriver (PH000) locate and remove the 4.45mm (.175in) screw by the 180 degree graphic on the metal ring.
      • The screws in the camera are very small and can strip very easily. Apply consistent pressure when removing screws.
      Vraag FixBot
      Voeg opmerking toe
    2. Contour Roam2 Mounting Piece Replacement: stap 2, afbeelding 1 van 2 Contour Roam2 Mounting Piece Replacement: stap 2, afbeelding 2 van 2
      • Rotate the metal ring counterclockwise until completely removed.
      Vraag FixBot
      Voeg opmerking toe
    3. Contour Roam2 Mounting Piece Replacement: stap 3, afbeelding 1 van 2 Contour Roam2 Mounting Piece Replacement: stap 3, afbeelding 2 van 2
      • Using the phillips head screwdriver (PH000) remove the two 4.46mm (.175in) screws on each side near the back of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Contour Roam2 Mounting Piece Replacement: stap 4, afbeelding 1 van 3 Contour Roam2 Mounting Piece Replacement: stap 4, afbeelding 2 van 3 Contour Roam2 Mounting Piece Replacement: stap 4, afbeelding 3 van 3
      • Grab the camera on both sides and slide the outer shell forward until completely removed.
      Vraag FixBot
      Voeg opmerking toe
    5. Contour Roam2 Mounting Piece Replacement: stap 5, afbeelding 1 van 1
      • Lift the record slider out.
      • The record slider should come out easily no matter the position (forward or backward).
      Vraag FixBot
      Voeg opmerking toe
    1. Contour Roam2 Mounting Piece Replacement, Mounting Piece: stap 6, afbeelding 1 van 2 Contour Roam2 Mounting Piece Replacement, Mounting Piece: stap 6, afbeelding 2 van 2
      • Using the phillips head screwdriver (PH000) remove the two 3.82mm (0.150in) screws on the bottom of mounting piece near the tripod screw-in.
      Vraag FixBot
      Voeg opmerking toe
    2. Contour Roam2 Mounting Piece Replacement: stap 7, afbeelding 1 van 2 Contour Roam2 Mounting Piece Replacement: stap 7, afbeelding 2 van 2
      • Open the back door by your thumb and index finger on sides of back door and pull upward.
      Vraag FixBot
      Voeg opmerking toe
    3. Contour Roam2 Mounting Piece Replacement: stap 8, afbeelding 1 van 1
      • Using your thumb, pry sides outward on back of mount piece.
      • This will loosen mount piece for removal in proceeding step.
      • Side can be hard to pry outward. Using a flat tool such as a metal spudger, may help if your thumb is insufficient.
      Vraag FixBot
      Voeg opmerking toe
    4. Contour Roam2 Mounting Piece Replacement: stap 9, afbeelding 1 van 2 Contour Roam2 Mounting Piece Replacement: stap 9, afbeelding 2 van 2
      • Remove and replace mount piece.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Matthew Kofsky
548 Reputatie
3 handleidingen geschreven
Colorado Springs, Team 4-5, Panko Spring 2015 Lid van Colorado Springs, Team 4-5, Panko Spring 2015
UCCS-PANKO-S15S4G5
3 Leden
10 handleidingen geschreven
2Gids Commentaar
Hi i need this part...
julmarte - Antwoord Deel
I Need a battery, and check up.
Too many small screws for me, I am using it on a home defense air powered 50 cal with orange top. need to have a mount for that Ball Shooter. where can I get that project I live in the 831 AC
Or is their something used already working I got this needing a battery.
Help from a Person I can mail it
Thanks Dudley
Dudley Walsh - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 34
Altijd: 1,917
