Inleiding
If your Concept2 rowing machine isn’t operating as smooth as it used to, it may be time to replace the chain. Replacing the chain on your rowing machine is a relatively simple process and necessary for maintaining your Concept2 machine. Neglecting this maintenance can lead to rust buildup and avoidable damage to other interior parts of your machine.
This guide details the chain replacement of a Model C/D/E Concept2 Rowing Machine. Steps 1 through 7 explain how to properly remove the damaged chain from a rowing machine while steps 8 though 14 detail reassembly.
This guide requires an adjustable wrench and phillips head screwdriver. The replacement parts and tools required for this guide can be purchased on Amazon.
Due to the size and weight of the average rowing machine, it may be in your best interest to find assistance in moving the machine. A majority of the steps in this guide require the machine to be positioned upside down to access the chain and necessary components. To prevent damage to the fan, the machine must be placed down gentle. Working in a wide open space or outdoors is likely in your best interest.
Wat je nodig hebt
Separate the front end of your rower from the seat portion by lifting up the handle in the center.
Set aside the seat portion of your rower.
Één andere persoon heeft deze handleiding voltooid.
