Ga door naar hoofdinhoud
Conair Cord-Keeper 169XR On/Off Switch Replacement
Wat je nodig hebt
  1. Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: stap 1, afbeelding 1 van 2 Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: stap 1, afbeelding 2 van 2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR On/Off Switch Replacement: stap 2, afbeelding 1 van 1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: stap 3, afbeelding 1 van 2 Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: stap 3, afbeelding 2 van 2
    • Now take out the On/Off switch by gently pulling it out towards you and lightly pushing it to the right with your finger until it comes out of the groove it is resting in.
    • Once the new switch is in place you can put the dryer back together.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Candace
992 Reputatie
7 handleidingen geschreven
Cal Poly, Team 10-33, Maness Winter 2014 Lid van Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 Leden
3 opmerkingen
Looks to me that a replacement switch would be required. How can obtain one?
Jaky Felix - Antwoord
“No parts required” is what’s displayed by default when there’s no link to an actual part for sale—it’’s a bit silly and clearly incorrect in this case. For hard-to-find parts, check eBay or Amazon. Also, a lot of folks with multiple broken units use these guides to cobble together one working unit from the parts. Good luck!
Jeff Suovanen -
That was my question, where can I get a replacement switch?
Constance Hudson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 20
Altijd: 3,050
