Ga door naar hoofdinhoud
Computer King Muffin Kinder 7 Logic Board Replacement
Wat je nodig hebt
  1. Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: stap 1, afbeelding 1 van 2 Computer King Muffin Kinder 7 Logic Board Replacement, Logic Board: stap 1, afbeelding 2 van 2
    • Use the plastic opening tool help push out the microSD card from the microSD slot.
  2. Computer King Muffin Kinder 7 Logic Board Replacement: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool to unclip the plastic front from the plastic back. Use the MicroSD slot to initially start the unclipping.
  3. Computer King Muffin Kinder 7 Logic Board Replacement: stap 3, afbeelding 1 van 2 Computer King Muffin Kinder 7 Logic Board Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the nine 3.0 mm Phillips #00 screws.
  4. Computer King Muffin Kinder 7 Logic Board Replacement: stap 4, afbeelding 1 van 1
    • The battery is glued onto the black plastic. Use the plastic opening tool to pry the battery from the black plastic
  5. Computer King Muffin Kinder 7 Logic Board Replacement: stap 5, afbeelding 1 van 3 Computer King Muffin Kinder 7 Logic Board Replacement: stap 5, afbeelding 2 van 3 Computer King Muffin Kinder 7 Logic Board Replacement: stap 5, afbeelding 3 van 3
    • Unsolder the 11 red, back, and grey wires connected to the logic board.
    • Tips on how to solder can be found here.
  6. Computer King Muffin Kinder 7 Logic Board Replacement: stap 6, afbeelding 1 van 3 Computer King Muffin Kinder 7 Logic Board Replacement: stap 6, afbeelding 2 van 3 Computer King Muffin Kinder 7 Logic Board Replacement: stap 6, afbeelding 3 van 3
    • Use the flat end of the spudger to lift the black panels covering the three ribbon cables connected to the logic board.
  7. Computer King Muffin Kinder 7 Logic Board Replacement: stap 7, afbeelding 1 van 1
    • Pull the three ribbon cables out so that they are no longer connected to the logic board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Katherine
439 Reputatie
3 handleidingen geschreven
UWT Liner: Group 2 Lid van UWT Liner: Group 2
Community
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 389
