Ga door naar hoofdinhoud
Compaq Evo N1000v Rear Fan Replacement
Wat je nodig hebt
    1. Compaq Evo N1000v Rear Fan Replacement, Rear Fan: stap 1, afbeelding 1 van 1
      • Carefully remove the screws located inside the red circles.
      Vraag FixBot
      Voeg opmerking toe
    2. Compaq Evo N1000v Rear Fan Replacement: stap 2, afbeelding 1 van 2 Compaq Evo N1000v Rear Fan Replacement: stap 2, afbeelding 2 van 2
      • Next, you will need to push down the "F1" key with the spudger and push it under the silver LED display panel.
      • Push down on the spudger to lift the LED display upward.
      • Do this on both the left and right sides of the device as shown in the images.
      Vraag FixBot
      Voeg opmerking toe
    3. Compaq Evo N1000v Rear Fan Replacement: stap 3, afbeelding 1 van 1
      • Completely remove the LED display panel from the device.
      Vraag FixBot
      Voeg opmerking toe
    4. Compaq Evo N1000v Rear Fan Replacement: stap 4, afbeelding 1 van 1
      • Lift the keyboard up from the back end as shown in the image.
      Vraag FixBot
      Voeg opmerking toe
    5. Compaq Evo N1000v Rear Fan Replacement: stap 5, afbeelding 1 van 1
      • Pull the keyboard slightly toward the screen of the device to reveal the connecting cable below.
      Vraag FixBot
      Voeg opmerking toe
    6. Compaq Evo N1000v Rear Fan Replacement: stap 6, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Follow the cable to its connection and use the grip tweezers to unlock the cable by grabbing the left side of the lock and pulling upward.
      • Repeat this action on the right side of the lock.
      Vraag FixBot
      Voeg opmerking toe
    7. Compaq Evo N1000v Rear Fan Replacement: stap 7, afbeelding 1 van 1
      • Pull the keyboard upward to remove it from the device.
      Vraag FixBot
      Voeg opmerking toe
    8. Compaq Evo N1000v Rear Fan Replacement: stap 8, afbeelding 1 van 1
      • Unscrew the 3 screws as shown in the photo.
      Vraag FixBot
      Voeg opmerking toe
    9. Compaq Evo N1000v Rear Fan Replacement: stap 9, afbeelding 1 van 1
      • Remove the cable with the grip tweezers as shown in the photo.
      Vraag FixBot
      Voeg opmerking toe
    10. Compaq Evo N1000v Rear Fan Replacement: stap 10, afbeelding 1 van 1
      • Remove the rear fan.
      • Repeat these steps in reverse order to install the new rear fan.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
ryan
470 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 2-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S2G1
3 Leden
8 handleidingen geschreven
1Gids Commentaar
My Big Thanks! I cleaned the radiator, cooler greased and replaced the thermal grease from the CPU and GPU.
DeK-Test New - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 31
Altijd: 817
