Ga door naar hoofdinhoud
Coin Counter Disassembly
Wat je nodig hebt
  1. Coin Counter Disassembly, Coin counter motherboard step 1: stap 1, afbeelding 1 van 1
    • I will be showing you how to look at the motherboard of a coin counter
    • the first step is to flip it to the back to see the little screws
    Vraag FixBot
    Voeg opmerking toe
  2. Coin Counter Disassembly, 2nd step for motherboard: stap 2, afbeelding 1 van 2 Coin Counter Disassembly, 2nd step for motherboard: stap 2, afbeelding 2 van 2
    • the second step is to remove the batteries.
    • To remove the batteries you have to take the top screw off
    • the second picture will show you how i toke out the screw in order to take out the batteries.to be safe when i get to the motherboard
    Vraag FixBot
    Voeg opmerking toe
  3. Coin Counter Disassembly, 3rd step: stap 3, afbeelding 1 van 3 Coin Counter Disassembly, 3rd step: stap 3, afbeelding 2 van 3 Coin Counter Disassembly, 3rd step: stap 3, afbeelding 3 van 3
    • the third step is to take out the 3 little screws in which side of the circle
    • In total you should have 3 screws. make sure you don"t lose them in case you want to put it back together
    Vraag FixBot
    Voeg opmerking toe
  4. Coin Counter Disassembly, 4th step: stap 4, afbeelding 1 van 2 Coin Counter Disassembly, 4th step: stap 4, afbeelding 2 van 2
    • The fourth step is to remove the othere crews from the motherboard. You need to remove the crews in order to take out the motherboard.
    • You have to have the 4 screws if your switch the motherboard to a other one.
    Vraag FixBot
    Voeg opmerking toe
  5. Coin Counter Disassembly, 5th step: stap 5, afbeelding 1 van 2 Coin Counter Disassembly, 5th step: stap 5, afbeelding 2 van 2
    • The 5th step is the hardest part because you have to now remove the red and black wires from both sides so then you can see the motherboard.
    • Be very careful removing or pulling the wires because it can break the other wires which will not work anymore.
    Vraag FixBot
    Voeg opmerking toe
  6. Coin Counter Disassembly, last step: stap 6, afbeelding 1 van 1
    • The last step is you got to the motherboard which was my goal. you could use the motherboard for other projects or just put it back for more a challenge.
    • My decisions was to put it back together, so then i can have more of a challenge. thank you for your time and i hoped this helped
    Vraag FixBot
    Voeg opmerking toe
Conclusie
osmar
101 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 45
Altijd: 691
