Ga door naar hoofdinhoud
Coby DVD-R11000 3-Pin Power Cable Replacement
Wat je nodig hebt
  1. Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: stap 1, afbeelding 1 van 3 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: stap 1, afbeelding 2 van 3 Coby DVD-R11000 3-Pin Power Cable Replacement, Outer Casing: stap 1, afbeelding 3 van 3
    • Remove the four 1cm screws, two on each side, of the DVD player with the Phillips #1 screwdriver.
    • Remove the five 1cm screws on the back of the DVD player with the Phillips #1 screwdriver.
    • It is not required to remove the other seven screws in the middle between the I/O ports.
    Vraag FixBot
    Voeg opmerking toe
  2. Coby DVD-R11000 3-Pin Power Cable Replacement: stap 2, afbeelding 1 van 3 Coby DVD-R11000 3-Pin Power Cable Replacement: stap 2, afbeelding 2 van 3 Coby DVD-R11000 3-Pin Power Cable Replacement: stap 2, afbeelding 3 van 3
    • Position the DVD player so that the back is facing you
    • Grab underneath the sides of the DVD player and lift the front of it upwards.
    • Carefully pull the top of the casing off
    Vraag FixBot
    Voeg opmerking toe
  3. Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: stap 3, afbeelding 1 van 2 Coby DVD-R11000 3-Pin Power Cable Replacement, 3-Pin Power Cable: stap 3, afbeelding 2 van 2
    • Gently pinch the 3-pin white adapter of the wire connecting the power cord to the circuit board.
    • Remove the wire from the circuit board.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Andrew
501 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 1-6, Shastany Fall 2014 Lid van UMass Dartmouth, Team 1-6, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G6
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 25
Altijd: 674
