Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Examine the garment where your ribbon button came off. There should be a little pocket where the ribbon came out.
Stitch rip the seam around the little pocket until it is large enough to easily slide the ribbon in.
Tuck one end of the ribbon into the pocket, inserting the ribbon past the missing seam.
Holding the ribbon in place, slide the garment into the sewing machine, aligning the presser foot with the place you want the button to sit.
Sew the ribbon in place.
Backstitch to hold the stitches in place.
Lift the presser foot and remove the garment from the sewing machine.
Clip any threads.
Thread the ribbon through the button coming up from behind, over the spoke in the middle, and back down through the second hole.
Pull the ribbon taught.
Fold the button and ribbon back over, so that the other side of the button is facing out.
Leave just enough ribbon to tuck into the little pocket. Clip all excess ribbon.
Fold the free end of the ribbon, tucking it into the little pocket, in the same manner as the first.
Overlap the two ends of the ribbon so that they sit directly on top of one another.
Sew directly over the seam, closing the little pocket.
Backstitch to hold the seam in place.
Remove the garment from the sewing machine.
Één andere persoon heeft deze handleiding voltooid.
