Ga door naar hoofdinhoud
ClickN Kids Tablet Touch Screen Display Replacement
Wat je nodig hebt
  1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: stap 1, afbeelding 1 van 1
    • Start on the side with the camera. The screen side is black, the back side is colored
    • Insert a plastic opening tool into the space between the screen and the back side.
    Vraag FixBot
    Voeg opmerking toe
  2. ClickN Kids Tablet Touch Screen Display Replacement: stap 2, afbeelding 1 van 1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
    Vraag FixBot
    Voeg opmerking toe
  3. ClickN Kids Tablet Touch Screen Display Replacement: stap 3, afbeelding 1 van 1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
    Vraag FixBot
    Voeg opmerking toe
  4. ClickN Kids Tablet Touch Screen Display Replacement: stap 4, afbeelding 1 van 2 ClickN Kids Tablet Touch Screen Display Replacement: stap 4, afbeelding 2 van 2
    • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
    • Once the ribbon cables are freed, separate the top and bottom sides.
    Vraag FixBot
    Voeg opmerking toe
  5. ClickN Kids Tablet Touch Screen Display Replacement: stap 5, afbeelding 1 van 2 ClickN Kids Tablet Touch Screen Display Replacement: stap 5, afbeelding 2 van 2
    • Remove the yellow tape on the right side. Easiest side to get.
    • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
    Vraag FixBot
    Voeg opmerking toe
  6. ClickN Kids Tablet Touch Screen Display Replacement: stap 6, afbeelding 1 van 1
    • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
    • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
    • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
    Vraag FixBot
    Voeg opmerking toe
  7. ClickN Kids Tablet Touch Screen Display Replacement: stap 7, afbeelding 1 van 2 ClickN Kids Tablet Touch Screen Display Replacement: stap 7, afbeelding 2 van 2
    • Be careful not to damage the display or screen case.
    • Pull the display from the top side to detach it from the screen case.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kevin Finney
562 Reputatie
4 handleidingen geschreven
Baylor, Team 4-4, Williams Spring 2015 Lid van Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 35
Altijd: 8,383
