Ga door naar hoofdinhoud
ClickN Kids Tablet Camera Replacement
Wat je nodig hebt
  1. ClickN Kids Tablet Camera Replacement, Camera: stap 1, afbeelding 1 van 1
    • Start on the side with the camera
    • Insert a plastic opening tool into the space between the screen and the back side.
    • The screen side is black, the back side is colored
    Vraag FixBot
  2. ClickN Kids Tablet Camera Replacement: stap 2, afbeelding 1 van 1
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
    • The corners can be tricky. Make sure to separate the pieces all the way around the tablet before attempting to open it.
    Vraag FixBot
  3. ClickN Kids Tablet Camera Replacement: stap 3, afbeelding 1 van 1
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Don't open too fast, or you might damage the ribbons cables.
    Vraag FixBot
  4. ClickN Kids Tablet Camera Replacement: stap 4, afbeelding 1 van 2 ClickN Kids Tablet Camera Replacement: stap 4, afbeelding 2 van 2
    • Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
    Vraag FixBot
  5. ClickN Kids Tablet Camera Replacement: stap 5, afbeelding 1 van 1
    • Pull off the tape that holds the ribbon cable to the battery.
    Vraag FixBot
  6. ClickN Kids Tablet Camera Replacement: stap 6, afbeelding 1 van 2 ClickN Kids Tablet Camera Replacement: stap 6, afbeelding 2 van 2
    • Be careful not to damage the wires or ribbon cables.
    • Pull out the two black ends of the base on the motherboard.
    • Slide out the camera’s ribbon cable once the ends are loosened.
    Vraag FixBot
  7. ClickN Kids Tablet Camera Replacement: stap 7, afbeelding 1 van 3 ClickN Kids Tablet Camera Replacement: stap 7, afbeelding 2 van 3 ClickN Kids Tablet Camera Replacement: stap 7, afbeelding 3 van 3
    • Use a plastic opening tool to pry the camera out of its place.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin Finney
562 Reputatie
4 handleidingen geschreven
Baylor, Team 4-4, Williams Spring 2015 Lid van Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Leden
8 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 54
Altijd: 1,065
