Ga door naar hoofdinhoud
Cleaning the Controller Buttons
Wat je nodig hebt
  1. Cleaning the Controller Buttons, Cleaning the Controller Buttons: stap 1, afbeelding 1 van 2 Cleaning the Controller Buttons, Cleaning the Controller Buttons: stap 1, afbeelding 2 van 2
    • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
    • Remove the back panel from the controller.
    Vraag FixBot
    Voeg opmerking toe
  2. Cleaning the Controller Buttons: stap 2, afbeelding 1 van 3 Cleaning the Controller Buttons: stap 2, afbeelding 2 van 3 Cleaning the Controller Buttons: stap 2, afbeelding 3 van 3
    • Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
    • Remove the back panel of the joystick box.
    • There are many small plastic components loose in this box; be careful not to lose these.
    • Separate the rubber pads and plastic buttons from the controller.
    Vraag FixBot
    Voeg opmerking toe
  3. Cleaning the Controller Buttons: stap 3, afbeelding 1 van 2 Cleaning the Controller Buttons: stap 3, afbeelding 2 van 2
    • Using a soft cleaning material, clean the plastic buttons.
    • Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
    Vraag FixBot
    Voeg opmerking toe
  4. Cleaning the Controller Buttons: stap 4, afbeelding 1 van 2 Cleaning the Controller Buttons: stap 4, afbeelding 2 van 2
    • Using a damp, soft cleaning material, clean the rubber button pads.
    • To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
    Vraag FixBot
    Voeg opmerking toe
  5. Cleaning the Controller Buttons, Put it back together: stap 5, afbeelding 1 van 1
    • Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Follow these steps in reverse order to reassemble your device.
7 andere personen hebben deze handleiding voltooid.
Jason Gittler
135 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 53
Altijd: 6,562
