Ga door naar hoofdinhoud
Chefman RJ38-V2-35 Repair Temperature Knob Replacement
Wat je nodig hebt
    1. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement, Temperature Knob: stap 1, afbeelding 1 van 1
      • Please be sure that the device is unplugged and remove the frying basket from the device.
      • Orient your device where the both the timer knob and temperature knob are facing you.
      • Slide the plastic opening tool under the temperature knob to lift it up.
      • You can slide your fingers in between the gap and take the temperature knob off.
      Vraag FixBot
      Voeg opmerking toe
    2. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 2, afbeelding 1 van 1
      • Using the Phillips #1 screwdriver, remove the two 4mm screws found under the temperature knob.
      • Place you fingers under the silver top and firmly lift it up.
      Vraag FixBot
      Voeg opmerking toe
    3. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 3, afbeelding 1 van 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 3, afbeelding 2 van 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 3, afbeelding 3 van 3
      • Using the Phillips #1 screwdriver, remove the two 3 mm screws found at the top of the black panel.
      • Pop off the top panel of the device with your fingers.
      Vraag FixBot
      Voeg opmerking toe
    4. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 4, afbeelding 1 van 1
      • Using a pair of scissors, cut off the cable cord that is securing the wire cords.
      Vraag FixBot
      Voeg opmerking toe
    5. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 5, afbeelding 1 van 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 5, afbeelding 2 van 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 5, afbeelding 3 van 3
      • Detach the device’s wires from the potentiometer.
      Vraag FixBot
      Voeg opmerking toe
    6. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: stap 6, afbeelding 1 van 1
      • Replace a new potentiometer to the device.
      • Attach the wires back to the new potentiometer.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Lucas Yi
177 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 52
Altijd: 3,176
