Ga door naar hoofdinhoud
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Wat je nodig hebt
  1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: stap 1, afbeelding 1 van 1
    • Place the meter face down, and the back panel and screws can be seen.
    Vraag FixBot
    Voeg opmerking toe
  2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: stap 2, afbeelding 1 van 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: stap 2, afbeelding 2 van 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: stap 3, afbeelding 1 van 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
    Vraag FixBot
    Voeg opmerking toe
  4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: stap 4, afbeelding 1 van 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: stap 4, afbeelding 2 van 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
    Vraag FixBot
    Voeg opmerking toe
  5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: stap 5, afbeelding 1 van 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
    Vraag FixBot
    Voeg opmerking toe
  6. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: stap 6, afbeelding 1 van 1
    • The screen is located at the top of the device.
    Vraag FixBot
    Voeg opmerking toe
  7. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: stap 7, afbeelding 1 van 1
    • Carefully remove screen from device by lifting upward.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Anna Kihm
965 Reputatie
5 handleidingen geschreven
Clemson, Team 2-4, Benson Fall 2014 Lid van Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Leden
6 handleidingen geschreven
1Gids Commentaar
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 3,064
