Ga door naar hoofdinhoud
Cen-Tech Seven Function Digital Multimeter Dial Replacement
Wat je nodig hebt
    1. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Position Device: stap 1, afbeelding 1 van 1
      • Place the meter face down, and the back panel and screws can be seen.
      Vraag FixBot
      Voeg opmerking toe
    2. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: stap 2, afbeelding 1 van 2 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel Screws: stap 2, afbeelding 2 van 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Back Panel: stap 3, afbeelding 1 van 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Vraag FixBot
      Voeg opmerking toe
    4. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: stap 4, afbeelding 1 van 2 Cen-Tech Seven Function Digital Multimeter Dial Replacement, Unscrew Motherboard: stap 4, afbeelding 2 van 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Vraag FixBot
      Voeg opmerking toe
    5. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Motherboard: stap 5, afbeelding 1 van 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Vraag FixBot
      Voeg opmerking toe
    1. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Locate Dial: stap 6, afbeelding 1 van 1
      • The dial is located in the central part of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Cen-Tech Seven Function Digital Multimeter Dial Replacement, Remove Dial: stap 7, afbeelding 1 van 1
      • Carefully remove dial from device by lifting upward.
      • Clean existing dial or replace if necessary.
      • Take care not to lose the small ball bearings.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Anna Kihm
965 Reputatie
5 handleidingen geschreven
Clemson, Team 2-4, Benson Fall 2014 Lid van Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Leden
18 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 22
Altijd: 1,220
