Ga door naar hoofdinhoud
Caterpillar B15 LCD Replacement
Wat je nodig hebt
  1. Caterpillar B15 LCD Replacement, Caterpillar B15 Teardown: stap 1, afbeelding 1 van 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
    Vraag FixBot
    Voeg opmerking toe
  2. Caterpillar B15 LCD Replacement: stap 2, afbeelding 1 van 2 Caterpillar B15 LCD Replacement: stap 2, afbeelding 2 van 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
    Vraag FixBot
    Voeg opmerking toe
  3. Caterpillar B15 LCD Replacement: stap 3, afbeelding 1 van 2 Caterpillar B15 LCD Replacement: stap 3, afbeelding 2 van 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
    Vraag FixBot
    Voeg opmerking toe
  4. Caterpillar B15 LCD Replacement: stap 4, afbeelding 1 van 2 Caterpillar B15 LCD Replacement: stap 4, afbeelding 2 van 2
    • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
    • WARNING: Proceeding beyond this point will void the warranty for this device.
    Vraag FixBot
    Voeg opmerking toe
  5. Caterpillar B15 LCD Replacement: stap 5, afbeelding 1 van 1
    • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
    Vraag FixBot
    Voeg opmerking toe
  6. Caterpillar B15 LCD Replacement: stap 6, afbeelding 1 van 1
    • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
    Vraag FixBot
    Voeg opmerking toe
  7. Caterpillar B15 LCD Replacement: stap 7, afbeelding 1 van 1
    • There is one more Phillips screw remaining. It is located beneath the headphone cover.
    Vraag FixBot
    Voeg opmerking toe
  8. Caterpillar B15 LCD Replacement: stap 8, afbeelding 1 van 1
    • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
    Vraag FixBot
    Voeg opmerking toe
  9. Caterpillar B15 LCD Replacement: stap 9, afbeelding 1 van 1
    • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
    Vraag FixBot
    Voeg opmerking toe
  10. Caterpillar B15 LCD Replacement: stap 10, afbeelding 1 van 1
    • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
    Vraag FixBot
    Voeg opmerking toe
  11. Caterpillar B15 LCD Replacement: stap 11, afbeelding 1 van 1
    • Congratulations. You have successfully disassembled the Caterpillar B15.
    Vraag FixBot
    Voeg opmerking toe
  12. Caterpillar B15 LCD Replacement, LCD: stap 12, afbeelding 1 van 1
    • With the device completely disassembled, the LCD can easily be accessed. It is pictured here, in which it adheres to the front of the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  13. Caterpillar B15 LCD Replacement: stap 13, afbeelding 1 van 1
    • The LCD is held to the board by an adhesive, and will peel away with either a spudger or by hand. Disconnect any ribbon cables if applicable.
    Vraag FixBot
    Voeg opmerking toe
  14. Caterpillar B15 LCD Replacement: stap 14, afbeelding 1 van 1
    • Installing the new LCD is the reverse of removing the old one. The 2mm 3M adhesive tape listed in the guide is recommended for fixing the new display to the board.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
9 andere personen hebben deze handleiding voltooid.
Geoffrey Mosdell
1.119 Reputatie
5 handleidingen geschreven
USF Tampa, Team 4-7, Brown Fall 2014 Lid van USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 25
Altijd: 7,556
