Ga door naar hoofdinhoud
Casio MH-10M Battery Replacement
Wat je nodig hebt
    1. Casio MH-10M Battery Replacement, BATTERY: stap 1, afbeelding 1 van 1
      • This is the calculator in question.
      • Features a black and white dot matrix screen.
      Vraag FixBot
      Voeg opmerking toe
    2. Casio MH-10M Battery Replacement: stap 2, afbeelding 1 van 2 Casio MH-10M Battery Replacement: stap 2, afbeelding 2 van 2
      • Turn the calculator over.
      • Locate the six screws on the rear of the device.
      • These are Philips #00 screws.
      • Keep the screws you remove in a safe place so they don't get lost.
      Vraag FixBot
      Voeg opmerking toe
    3. Casio MH-10M Battery Replacement: stap 3, afbeelding 1 van 2 Casio MH-10M Battery Replacement: stap 3, afbeelding 2 van 2
      • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
      • Place the panel to one side.
      • You can now see the battery.
      Vraag FixBot
      Voeg opmerking toe
    4. Casio MH-10M Battery Replacement: stap 4, afbeelding 1 van 1
      • Remove the battery
      • Lift it up from the right hand side to avoid damaging the spring.
      • You may find this easier to do by prying it out with the screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Casio MH-10M Battery Replacement: stap 5, afbeelding 1 van 2 Casio MH-10M Battery Replacement: stap 5, afbeelding 2 van 2
      • Now you can insert the new battery
      • Ensure you place it in spring-first.
      • Congratulations! You have replaced the battery.
      • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
      • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
26 andere personen hebben deze handleiding voltooid.
Sam
977 Reputatie
1 Handleiding geschreven
3Gids Commentaar
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Antwoord Deel
what battery size is it? R03?
Humerdom - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 58
Altijd: 50,115
