Ga door naar hoofdinhoud
Casio LK-170 Speaker Replacement
Wat je nodig hebt
  1. Casio LK-170 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 3 Casio LK-170 Speaker Replacement, Speaker: stap 1, afbeelding 2 van 3 Casio LK-170 Speaker Replacement, Speaker: stap 1, afbeelding 3 van 3
    • Locate the seven 11mm screws on the back of the keyboard in order to remove the speaker from the front of the keyboard.
    • There are 7 screws that need to be removed in total to replace one speaker. Use a JIS-1 screwdriver to remove these screws: 2 on the back panel, and 4 on the side of the keyboard.
    • Three of these seven screws are slightly hidden and may be hard to find.
  2. Casio LK-170 Speaker Replacement: stap 2, afbeelding 1 van 2 Casio LK-170 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Gently remove the speaker and its compartment from the front of the keyboard.
  3. Casio LK-170 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the four 11 mm screws with JIS-1 screwdriver on the four corners of the silver square on the back of the speaker.
  4. Casio LK-170 Speaker Replacement: stap 4, afbeelding 1 van 2 Casio LK-170 Speaker Replacement: stap 4, afbeelding 2 van 2
    • A soldering iron is needed to remove the wires connected to the speaker in order to fully replace it. For soldering help, take a look at the Soldering and Desoldering Connections guide.
    • Desolder the metal that attaches the blue and white wires to the speaker.
    • Remove the speaker.
Conclusie
Samantha Baker
425 Reputatie
4 handleidingen geschreven
Cal Poly, Team 13-2, Banghart Winter 2017 Lid van Cal Poly, Team 13-2, Banghart Winter 2017
CPSU-BANGHART-W17S13G2
3 Leden
5 handleidingen geschreven
Één opmerking
How much is a replacement speaker and where do I get one for the BRAND new keyboard U just bought that doesnt work through the left speaker (LK 265)
Heather Quigley - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 16
Altijd: 702
