Ga door naar hoofdinhoud
Casio FX-115MS Keyboard Mat Replacement
Wat je nodig hebt
  1. Casio FX-115MS  Keyboard Mat Replacement, Back Plate: stap 1, afbeelding 1 van 1
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Casio FX-115MS  Keyboard Mat Replacement: stap 2, afbeelding 1 van 3 Casio FX-115MS  Keyboard Mat Replacement: stap 2, afbeelding 2 van 3 Casio FX-115MS  Keyboard Mat Replacement: stap 2, afbeelding 3 van 3
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
    Vraag FixBot
    Voeg opmerking toe
  3. Casio FX-115MS  Keyboard Mat Replacement, Battery: stap 3, afbeelding 1 van 2 Casio FX-115MS  Keyboard Mat Replacement, Battery: stap 3, afbeelding 2 van 2
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
    Vraag FixBot
    Voeg opmerking toe
  4. Casio FX-115MS  Keyboard Mat Replacement, Motherboard and Screen: stap 4, afbeelding 1 van 2 Casio FX-115MS  Keyboard Mat Replacement, Motherboard and Screen: stap 4, afbeelding 2 van 2
    • Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
    Vraag FixBot
    Voeg opmerking toe
  5. Casio FX-115MS  Keyboard Mat Replacement: stap 5, afbeelding 1 van 3 Casio FX-115MS  Keyboard Mat Replacement: stap 5, afbeelding 2 van 3 Casio FX-115MS  Keyboard Mat Replacement: stap 5, afbeelding 3 van 3
    • Using the small metal spudger. Carefully pry around the edge of the solar panel until it becomes loose. Then simply pull it from its socket using your hands.
    Vraag FixBot
    Voeg opmerking toe
  6. Casio FX-115MS  Keyboard Mat Replacement: stap 6, afbeelding 1 van 2 Casio FX-115MS  Keyboard Mat Replacement: stap 6, afbeelding 2 van 2
    • Using a PH0 phillips screwdriver, unscrew the four, 4mm, pan head screws from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  7. Casio FX-115MS  Keyboard Mat Replacement: stap 7, afbeelding 1 van 3 Casio FX-115MS  Keyboard Mat Replacement: stap 7, afbeelding 2 van 3 Casio FX-115MS  Keyboard Mat Replacement: stap 7, afbeelding 3 van 3
    • Carefully lift the motherboard, screen, solar panel, and battery terminal combination from the front plate. Start from the motherboard and lift at an angle toward the solar panel.
    Vraag FixBot
    Voeg opmerking toe
  8. Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: stap 8, afbeelding 1 van 3 Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: stap 8, afbeelding 2 van 3 Casio FX-115MS  Keyboard Mat Replacement, Keyboard Mat: stap 8, afbeelding 3 van 3
    • Starting from one corner of the keyboard mat, slowly peel the mat from the front plate and individual keys.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Fady Baskharoun
274 Reputatie
2 handleidingen geschreven
USF Tampa, Team 2-2, Nance Fall 2016 Lid van USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 Leden
15 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 58
Altijd: 882
