Ga door naar hoofdinhoud
Casio CZ-1000 Display Screen Replacement
Wat je nodig hebt
  1. Casio CZ-1000 Display Screen Replacement, Backplate: stap 1, afbeelding 1 van 2 Casio CZ-1000 Display Screen Replacement, Backplate: stap 1, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
    Vraag FixBot
    Voeg opmerking toe
  2. Casio CZ-1000 Display Screen Replacement: stap 2, afbeelding 1 van 3 Casio CZ-1000 Display Screen Replacement: stap 2, afbeelding 2 van 3 Casio CZ-1000 Display Screen Replacement: stap 2, afbeelding 3 van 3
    • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
    • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
    Vraag FixBot
    Voeg opmerking toe
  3. Casio CZ-1000 Display Screen Replacement: stap 3, afbeelding 1 van 3 Casio CZ-1000 Display Screen Replacement: stap 3, afbeelding 2 van 3 Casio CZ-1000 Display Screen Replacement: stap 3, afbeelding 3 van 3
    • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
    • Be sure to avoid cutting any nearby wires or components.
    • Gently slide all the plugs out of their sockets.
    • This will prevent them from catching on anything or damaging the connectors as you lift.
    Vraag FixBot
    Voeg opmerking toe
  4. Casio CZ-1000 Display Screen Replacement, Display Screen: stap 4, afbeelding 1 van 2 Casio CZ-1000 Display Screen Replacement, Display Screen: stap 4, afbeelding 2 van 2
    • Pull out the orange 24 pin connector.
    • Pull on the orange plastic piece and not the wires. Pulling on the wires can potentially damage the device.
    Vraag FixBot
    Voeg opmerking toe
  5. Casio CZ-1000 Display Screen Replacement: stap 5, afbeelding 1 van 2 Casio CZ-1000 Display Screen Replacement: stap 5, afbeelding 2 van 2
    • Remove the four 7.5 mm screws that are holding down the metal sheets using a Phillips #1 screwdriver.
    • Set the sheet to the side for now.
    Vraag FixBot
    Voeg opmerking toe
  6. Casio CZ-1000 Display Screen Replacement: stap 6, afbeelding 1 van 3 Casio CZ-1000 Display Screen Replacement: stap 6, afbeelding 2 van 3 Casio CZ-1000 Display Screen Replacement: stap 6, afbeelding 3 van 3
    • Remove the four 5.5 mm screws from the corners of the display screen using a Phillips #1 screwdriver.
    • Lift the side of the display screen that is closer to you and then pull out the screen.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Ayman Benbrahim
97 Reputatie
1 Handleiding geschreven
Cuesta, Team 60-3, Krynen Fall 2024 Lid van Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Leden
5 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 17
Altijd: 272
