Ga door naar hoofdinhoud
Casio CTK-501 Battery Connection Replacement
Wat je nodig hebt
  1. Casio CTK-501 Battery Connection Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Casio CTK-501 Battery Connection Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Flip the keyboard over so that the bottom is facing up.
    • Remove the twenty-seven 12 mm screws from the dark-grey panel using a Phillips #2 screwdriver.
  2. Casio CTK-501 Battery Connection Replacement: stap 2, afbeelding 1 van 1
    • Remove the bottom panel by lifting and pulling it towards yourself.
  3. Casio CTK-501 Battery Connection Replacement: stap 3, afbeelding 1 van 2 Casio CTK-501 Battery Connection Replacement: stap 3, afbeelding 2 van 2
    • Flip open the top half of the keyboard.
    • Set the keyboard onto the bottom half with the internal parts facing up.
    • Be careful not to let the bottom drop.
  4. Casio CTK-501 Battery Connection Replacement, Battery Connection: stap 4, afbeelding 1 van 1
    • Plug in the soldering iron.
    • Set the soldering iron somewhere safe, where it can't catch anything on fire.
    • Unscrew the top green circuit board with black and red wires running through it.
  5. Casio CTK-501 Battery Connection Replacement: stap 5, afbeelding 1 van 1
    • Set the circuit board somewhere flat so it is safe to solder.
  6. Casio CTK-501 Battery Connection Replacement: stap 6, afbeelding 1 van 1
    • Heat up the solder covering the end of the wires connected to the circuit board.
    • Once the solder melts, remove the wires from the circuit board.
  7. Casio CTK-501 Battery Connection Replacement: stap 7, afbeelding 1 van 1
    • Melt new solder with your soldering iron.
    • Then apply it over the tip of the wire resting on the circuit board.
  8. Casio CTK-501 Battery Connection Replacement: stap 8, afbeelding 1 van 1
    • Once the wires are firmly attached, screw the circuit board back into the keyboard.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Jimmy Winne
578 Reputatie
6 handleidingen geschreven
Cal Poly, Team 9-16, Amido Fall 2012 Lid van Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Leden
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 46
Altijd: 5,316
