Inleiding
The controller might stopped working due a malfunction error on the circuit board that you might want to consider replacing. This guide requires soldering. For more information on how to solder and desolder connections, please visit this guide.
Wat je nodig hebt
Flip the controller over so the underside would face up
Remove four of 7.1mm screws with a JIS #1 screwdriver
Remove two 4.0mm screws located on the handle with the JIS #1screwdriver.
Remove two 7.1 mm screws on the small area that stick out from the surface with the JIS #1 screwdriver
Één andere persoon heeft deze handleiding voltooid.
