Ga door naar hoofdinhoud
Carrera Mario Copter Controller Circuit Board Replacement
Wat je nodig hebt
  1. Carrera Mario Copter Controller Circuit Board Replacement, Controller Circuit Board: stap 1, afbeelding 1 van 1
    • Flip the controller over so the underside would face up
    • Remove four of 7.1mm screws with a JIS #1 screwdriver
    • Remove two 4.0mm screws located on the handle with the JIS #1screwdriver.
    • Remove two 7.1 mm screws on the small area that stick out from the surface with the JIS #1 screwdriver
    • Use an extension with the JIS #1 screwdriver in order to get to the screws with yellow marks because they locate deep inside the holes.
  2. Carrera Mario Copter Controller Circuit Board Replacement: stap 2, afbeelding 1 van 1
    • Remove the black case to access the circuit board.
    • Remove two 4.8mm screws on the circuit board with the JIS #1 screwdriver.
  3. Carrera Mario Copter Controller Circuit Board Replacement: stap 3, afbeelding 1 van 1
    • Gently lift up the circuit board from the black case.
    • Use a soldering iron to melt the red wire while at the same time pulling it from the motherboard.
    • For more information on how to solder and desolder connections, please visit this guide.
    • Repeat the previous procedure with the black wire.
    • Gently remove the circuit board away from the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Edgar Lopez-Allende
207 Reputatie
2 handleidingen geschreven
UW Tacoma, Team S1-G6, Rose Fall 2017 Lid van UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 269
