Ga door naar hoofdinhoud
Capresso Perfectea 260 Lid Replacement
Wat je nodig hebt
  1. Capresso Perfectea 260 Lid Replacement, Lid: stap 1, afbeelding 1 van 1
    • Lift the lid of the Perfectea
    • Remove the two 12mm Phillips #2 screws located at the brim of the pot.
    Vraag FixBot
    Voeg opmerking toe
  2. Capresso Perfectea 260 Lid Replacement: stap 2, afbeelding 1 van 3 Capresso Perfectea 260 Lid Replacement: stap 2, afbeelding 2 van 3 Capresso Perfectea 260 Lid Replacement: stap 2, afbeelding 3 van 3
    • Adhesive tape is left holding the lid to the glass pot.
    • Use the spudger for this step.
    • With one hand, firmly grip the lid while designating your other hand to wedge the spudger between the lid and the glass pot.
    • Working from the outside to the inside, gently pry the adhesive tape from the glass pot, detaching the lid.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Kenji Anzai
594 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-17, Maness Spring 2015 Lid van Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Leden
12 handleidingen geschreven
2Gids Commentaar
This guide applies to the Capresso H2O kettle too. Thanks for the guide.
Giovanni Ciriani - Antwoord Deel
What kind of adhesive tape is it and where can I get some? That piece that you pried off had already fallen off of my kettle.
George Shaeffer - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 32
Altijd: 1,030
