Ga door naar hoofdinhoud
Capresso Perfectea 260 Control System Replacement
Wat je nodig hebt
    1. Capresso Perfectea 260 Control System Replacement, Motherboard: stap 1, afbeelding 1 van 1
      • First, take the base of the device and flip it over.
      Vraag FixBot
      Voeg opmerking toe
    2. Capresso Perfectea 260 Control System Replacement: stap 2, afbeelding 1 van 2 Capresso Perfectea 260 Control System Replacement: stap 2, afbeelding 2 van 2
      • Remove the four 12 mm Phillips #2 screws surrounding the base then lift the bottom half of the base to expose the circuit boards inside the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Capresso Perfectea 260 Control System Replacement: stap 3, afbeelding 1 van 1
      • Remove the two 7.5 mm Phillips #2 screws holding in the motherboard
      Vraag FixBot
      Voeg opmerking toe
    4. Capresso Perfectea 260 Control System Replacement: stap 4, afbeelding 1 van 1
      • Unplug the wire going into the side of the motherboard
      Vraag FixBot
      Voeg opmerking toe
    5. Capresso Perfectea 260 Control System Replacement: stap 5, afbeelding 1 van 2 Capresso Perfectea 260 Control System Replacement: stap 5, afbeelding 2 van 2
      • Use the metal spudger to cut open the rubber covering the latch where it clamps onto the copper tab.
      • Unplug wire at heating element by first using the metal spudger to push the latch in and then pushing it out.
      • Be careful when unplugging the wire as if it is done too forcefully it can damage the connection and make it difficult to connect a new motherboard
      Vraag FixBot
      Voeg opmerking toe
    6. Capresso Perfectea 260 Control System Replacement: stap 6, afbeelding 1 van 1
      • Lift the motherboard out of the device
      Vraag FixBot
      Voeg opmerking toe
    1. Capresso Perfectea 260 Control System Replacement, Control System: stap 7, afbeelding 1 van 2 Capresso Perfectea 260 Control System Replacement, Control System: stap 7, afbeelding 2 van 2
      • Remove the two 7.5mm Phillips #2 screws from the metal frame.
      • Remove the frame from the assembly.
      Vraag FixBot
      Voeg opmerking toe
    2. Capresso Perfectea 260 Control System Replacement: stap 8, afbeelding 1 van 3 Capresso Perfectea 260 Control System Replacement: stap 8, afbeelding 2 van 3 Capresso Perfectea 260 Control System Replacement: stap 8, afbeelding 3 van 3
      • Remove the two 6mm fine thread Phillips #2 screws attaching the small computer chip to the metal frame.
      • Flip over and remove the 7.5 mm fine thread Phillips #2 screw from the back while holding the 5mm nut on the front securely.
      Vraag FixBot
      Voeg opmerking toe
    3. Capresso Perfectea 260 Control System Replacement: stap 9, afbeelding 1 van 3 Capresso Perfectea 260 Control System Replacement: stap 9, afbeelding 2 van 3 Capresso Perfectea 260 Control System Replacement: stap 9, afbeelding 3 van 3
      • Find the cable that attaches the small computer chip to the heating element connections.
      • Use the spudger to cut open the rubber coating on the latch where it clamps onto the copper tab.
      • Insert the metal spudger into the rectangular hole on the latch and push toward the tab (away from the wire) to unbend the tab.
      • Push the latch off the tab with the spudger.
      • The tab will come loose suddenly. Make sure that you apply force in a controlled manner to avoid injuring yourself or damaging the other components.
      Vraag FixBot
      Voeg opmerking toe
    4. Capresso Perfectea 260 Control System Replacement: stap 10, afbeelding 1 van 3 Capresso Perfectea 260 Control System Replacement: stap 10, afbeelding 2 van 3 Capresso Perfectea 260 Control System Replacement: stap 10, afbeelding 3 van 3
      • Identify the two computer chips that connect the two yellow wires to the temperature controls.
      • Remove the four 5 mm Phillips #1 screws.
      • Remove the two computer chips from their places.
      • The two computer chips are held in place by plastic interference pins. Wiggle the board free of these pins to remove.
      Vraag FixBot
      Voeg opmerking toe
    5. Capresso Perfectea 260 Control System Replacement: stap 11, afbeelding 1 van 3 Capresso Perfectea 260 Control System Replacement: stap 11, afbeelding 2 van 3 Capresso Perfectea 260 Control System Replacement: stap 11, afbeelding 3 van 3
      • Find the computer chip over the dial.
      • Remove the three 6mm Phillips #2 screws.
      • Remove the computer chip.
      • Remember the orientation of the computer chip on the dial and which peg goes into which hole.
      • Keep the plastic frame on the bottom of the chip attached.
      Vraag FixBot
      Voeg opmerking toe
    6. Capresso Perfectea 260 Control System Replacement: stap 12, afbeelding 1 van 1
      • Unplug the four cables on the left side of the chip.
      • Remember which cable goes to which plug.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kenji Anzai
594 Reputatie
4 handleidingen geschreven
Cal Poly, Team 6-17, Maness Spring 2015 Lid van Cal Poly, Team 6-17, Maness Spring 2015
CPSU-MANESS-S15S6G17
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 41
Altijd: 2,921
