Ga door naar hoofdinhoud
Canon Powershot Pro1 Lens Replacement
Wat je nodig hebt
    1. Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: stap 1, afbeelding 1 van 2 Canon Powershot Pro1 Lens Replacement, The Lens of a Cannon Powershot Pro1: stap 1, afbeelding 2 van 2
      • Have the lens of the camera facing upwards.
      • Find the red plastic ring.
      • Look for two small opening above the red plastic ring.
      • Reference to the left of the picture and you will see the orange square.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon Powershot Pro1 Lens Replacement: stap 2, afbeelding 1 van 3 Canon Powershot Pro1 Lens Replacement: stap 2, afbeelding 2 van 3 Canon Powershot Pro1 Lens Replacement: stap 2, afbeelding 3 van 3
      • Remove the plastic ring that has a red strip.
      • Remove the 1.5 mm Phillips #1 screws which lie underneath the ring.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon Powershot Pro1 Lens Replacement: stap 3, afbeelding 1 van 3 Canon Powershot Pro1 Lens Replacement: stap 3, afbeelding 2 van 3 Canon Powershot Pro1 Lens Replacement: stap 3, afbeelding 3 van 3
      • Place the camera on its back with the lens facing upwards as shown in the image
      • Remove the additional 1.5 mm Phillip #1 screw from underneath the lens cover
      • Remove the screw by turning the Philip driver counterclockwise.
      • By removing the screw, you will be able to remove the cover lens.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon Powershot Pro1 Lens Replacement: stap 4, afbeelding 1 van 1
      • Use the nylon spudger to remove the ring holding the lens in place.
      • Pull gently until the lens ring snaps off.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon Powershot Pro1 Lens Replacement: stap 5, afbeelding 1 van 1
      • Refer to the left-hand pictere to see what the len's ring looks like.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon Powershot Pro1 Lens Replacement: stap 6, afbeelding 1 van 3 Canon Powershot Pro1 Lens Replacement: stap 6, afbeelding 2 van 3 Canon Powershot Pro1 Lens Replacement: stap 6, afbeelding 3 van 3
      • Take out the lens once the plastic ring is removed
      • Hold the outer layer of the lens to not create smudges on it.
      • Replace the lens and follow the instruction in reversed order to reassemble the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Seana Meegan
677 Reputatie
5 handleidingen geschreven
1Gids Commentaar
Hi, can you do a guide on how to repair the diaphragm?
OTVaL - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 67
Altijd: 4,076
