Ga door naar hoofdinhoud
Inleiding
This guide will walk you through replacing a damaged speaker in your Canon Powershot ELPH 100.
This process involves soldering—make sure you are proficient at soldering before attempting this task.
Because many soldering irons take time to heat up, turn yours on before beginning. This will save you time later on in the procedure.
  1. Locate the battery cover on the bottom of your camera. Slide the tab to the right to open the battery cover. Slide the tab to the right to open the battery cover.
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Flip the battery cover open. Using your fingers, slide the battery out of the camera.
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
  3. Push down on the memory card until it clicks and releases. Pull up on the memory card to remove it. Pull up on the memory card to remove it.
    • Push down on the memory card until it clicks and releases.
    • Pull up on the memory card to remove it.
  4. Using the Phillips #00, remove the two 3.1mm screws from the bottom of the camera.
    • Using the Phillips #00, remove the two 3.1mm screws from the bottom of the camera.
    • The display screen of the camera should be facing towards you.
  5. With the screen facing you, rotate the camera counter clock-wise onto it's side.
    • With the screen facing you, rotate the camera counter clock-wise onto it's side.
    • Remove the two 3.1mm screws.
  6. With the screen still facing you, rotate the camera 180 degrees.
    • With the screen still facing you, rotate the camera 180 degrees.
    • The side with the charging port should now be facing up.
  7. Use the plastic opening tool (or fingers) to pry open the charging port cover. Rotate the cover so that you have access to the screw underneath.
    • Use the plastic opening tool (or fingers) to pry open the charging port cover.
    • Rotate the cover so that you have access to the screw underneath.
    • Remove both 3.1mm screws.
    • The image still shows the screw from step 3 in place.
  8. Turn the camera so the bottom is once again facing up. With the battery door still open, use a spudger to remove the cover from the front of the camera.
    • Turn the camera so the bottom is once again facing up.
    • With the battery door still open, use a spudger to remove the cover from the front of the camera.
  9. Pull off the the front cover.
    • Pull off the the front cover.
    • Be careful not to break the tabs that hold it in place.
  10. Use the spudger to remove the back cover. Be careful not to break the tabs. Be careful not to break the tabs.
    • Use the spudger to remove the back cover.
    • Be careful not to break the tabs.
  11. Turn on soldering Iron.
    • Turn on soldering Iron.
  12. Gently remove the tabs surrounding the power button on the housing of the camera. Be careful not to break the wires that connect the housing to the body of the camera. Be careful not to break the wires that connect the housing to the body of the camera.
    • Gently remove the tabs surrounding the power button on the housing of the camera.
    • Be careful not to break the wires that connect the housing to the body of the camera.
  13. Make sure the battery is removed.
    • Make sure the battery is removed.
    • Cut the wires half way between the microphone and body of camera.
    • Leave 25mm of wire on the speaker when cutting the wire
  14. Strip the ends of the newly cut wires.
    • Strip the ends of the newly cut wires.
    • Expose only 2 mm of bare wire.
  15. Remove the 3.1mm screw holding speaker to the housing. Remove the two clips and the metal cover will be released When you remove the metal cover the spring will shoot out.
    • Remove the 3.1mm screw holding speaker to the housing.
    • Remove the two clips and the metal cover will be released
    • When you remove the metal cover the spring will shoot out.
    • Take note of the spring and its orientation, it will need to be re-installed later
    • Image of the spring
  16. Using tweezers, grab the wires to pull the speaker from the plastic housing. Use force as the speaker is glued to the housing.
    • Using tweezers, grab the wires to pull the speaker from the plastic housing.
    • Use force as the speaker is glued to the housing.
  17. Test the heat of the soldering iron by touching it to the tip of a paperclip.
    • Test the heat of the soldering iron by touching it to the tip of a paperclip.
    • If the tip of the paperclip melts, the iron should be ready.
    • If you have never used a soldering iron before, please consult the tutorial in the description of this guide, or watch the following video: How To Solder Or Soldering Techniques.
  18. Solder the red wire to the right terminal, and the black wire to the left terminal.
    • Solder the red wire to the right terminal, and the black wire to the left terminal.
    • Do not apply force to the speaker wires during this step. If the wires break, you will need to re-solder them.
  19. Place the speaker back in it's housing.
    • Place the speaker back in it's housing.
  20. Place the metal cover over the speaker.
    • Place the metal cover over the speaker.
    • Do not attach the screw.
  21. Lift up the corner of the metal cover and slide the spring in so it rests around the screw hole. After the spring is around the screw hole post, replace the screw so that the cover stays in place.
    • Lift up the corner of the metal cover and slide the spring in so it rests around the screw hole.
    • After the spring is around the screw hole post, replace the screw so that the cover stays in place.
  22. To reattach the speaker housing to the rest of the camera, make sure the pins and clips are aligned.
    • To reattach the speaker housing to the rest of the camera, make sure the pins and clips are aligned.
Conclusie
To reassemble your device, follow the case disassembly guide in reverse.
Één andere persoon heeft deze handleiding voltooid.
Bijgevoegde documenten
Jacob
492 Reputatie
3 handleidingen geschreven
Michigan Tech, Team 1-10, Lauer Spring 2015 Lid van Michigan Tech, Team 1-10, Lauer Spring 2015
MTU-LAUER-S15S1G10
2 Leden
5 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 601
