Ga door naar hoofdinhoud
Canon Powershot ELPH 100 HS Battery Replacement
  1. Canon Powershot ELPH 100 HS Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Canon Powershot ELPH 100 HS Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the battery cover on the bottom of your camera.
    • Slide the tab to the right to open the battery cover.
  2. Canon Powershot ELPH 100 HS Battery Replacement: stap 2, afbeelding 1 van 2 Canon Powershot ELPH 100 HS Battery Replacement: stap 2, afbeelding 2 van 2
    • Flip the battery cover open.
    • Using your fingers, slide the battery out of the camera.
    • This was not the original battery that came the camera, so yours may look different.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lillia
255 Reputatie
2 handleidingen geschreven
Michigan Tech, Team 1-10, Lauer Spring 2015 Lid van Michigan Tech, Team 1-10, Lauer Spring 2015
MTU-LAUER-S15S1G10
2 Leden
5 handleidingen geschreven
2 opmerkingen
What if the internal time/date battery is bad? A fully charged battery will drain crazy fast because the rechargeable internal No longer charges. Is there a fix?
S Silvia - Antwoord
Hi @ssilvia, there isn't a guide specifically for the CMOS or coin cell battery replacement but the Canon Powershot ELPH 100 HS Outer Case Replacement guide has an image that confirms there is a coin cell battery. It looks like you should be able to access and replace it. The photo is a little blurry so I couldn't read the specific size. I hope this helps or at least this might get you started on the repair. Thanks!
Sarah Westberg -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 46
Altijd: 1,631
