Inleiding
This guide will help you remove and replace your Canon Powershot A610 speaker, bringing back the ability for your camera to use the Sound Memo Function and shutter effects again as long as that was the only underlying issue.
Before beginning this repair, power off the camera, disconnect from the power adapter, and remove the battery.
This repair requires soldering so if you're not experienced, ask for assistance and take a look at the How to Solder and Desolder Connections for more information.
Wat je nodig hebt
Remove the three screws attaching the side panel using a Phillips #00 screwdriver.
Remove the side paneling from the camera.
Remove the two remaining screws attached to the frame of the camera.
