Ga door naar hoofdinhoud
Canon PowerShot SX600 HS Flash Assembly Replacement
Wat je nodig hebt
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Battery: stap 1, afbeelding 1 van 1
      • To remove the battery, locate the battery cover on the bottom of the camera.
      • Using your thumb, press down on the cover and slide it outwards.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 2, afbeelding 1 van 1
      • Depress the orange lever holding the battery in place to unlock it.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX600 HS Flash Assembly Replacement: stap 3, afbeelding 2 van 2
      • Use your fingers to remove the battery.
      • Be sure to remember the alignment of the nodes for reassembly.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Power and Shutter Buttons: stap 4, afbeelding 1 van 1
      • Use a #000 Phillips screwdriver to unscrew the four 4mm screws located on the sides of the camera (2 for each side).
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 5, afbeelding 1 van 1
      • Unscrew the four 2mm located on the bottom of the camera using a Phillips #000 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 6, afbeelding 1 van 1
      • Use a plastic opening tool to loosen and remove both the front and back plates of the camera, as well as the two side pieces.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot SX600 HS Flash Assembly Replacement: stap 7, afbeelding 2 van 2
      • Unscrew the three 2mm screws attaching the piece to the camera frame with a #000 Phillips screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 8, afbeelding 1 van 1
      • Use an opening tool to gently remove the power and shutter button assembly from the frame.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: stap 9, afbeelding 1 van 2 Canon PowerShot SX600 HS Flash Assembly Replacement, Display Screen: stap 9, afbeelding 2 van 2
      • Unscrew the 2mm screw connections of the main board protector from the camera frame using a #000 Phillips head screwdriver (2 on front, 1 on top)
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 10, afbeelding 1 van 1
      • Use a Phillips #000 screwdriver to unscrew the 4mm screw.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 11, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use a pair of tweezers to remove the no-fuss connector from its holder.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 12, afbeelding 1 van 1
      • Gently lift the protector from the frame.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 13, afbeelding 1 van 1
      • Lift the LCD screen ZIF connector tab and remove the ribbon cable.
      • Detach the no-fuss connector.
      • Lift the screen from its holder.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot SX600 HS Flash Assembly Replacement, Flash Assembly: stap 14, afbeelding 1 van 1
      • Unplug the assembly from the main no-fuss connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 15, afbeelding 1 van 1
      • Unplug the assembly from its flat-top connection.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 16, afbeelding 1 van 1
      • Use a #000 Phillips screwdriver to remove the three 4mm screws that hold the assembly to the frame.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot SX600 HS Flash Assembly Replacement: stap 17, afbeelding 1 van 1
      • Gently lift the assembly out of its place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Fix your Canon's flash in order to take bright, vibrant photographs.
Scott Childress
761 Reputatie
3 handleidingen geschreven
USF Tampa, Team S6-G4, Lacy Spring 2017 Lid van USF Tampa, Team S6-G4, Lacy Spring 2017
USFT-LACY-S17S6G4
3 Leden
9 handleidingen geschreven
1Gids Commentaar
my SX610 HS flash didn't work. im trying to just troubleshoot it to see if it might came loose or anything. do i still need to do all steps?
Nurul Huda Mohd Asri - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 45
Altijd: 1,489
