Ga door naar hoofdinhoud
Canon PowerShot SX60 HS Back Panel Replacement
Wat je nodig hebt
    1. Canon PowerShot SX60 HS Back Panel Replacement, Back Panel: stap 1, afbeelding 1 van 1
      • Make sure to power off the device before completing any more steps.
      • Remove the battery by releasing the orange clip in the battery compartment.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SX60 HS Back Panel Replacement: stap 2, afbeelding 1 van 2 Canon PowerShot SX60 HS Back Panel Replacement: stap 2, afbeelding 2 van 2
      • Remove the rubber eye piece by pulling it back.
      • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the side of the viewfinder.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SX60 HS Back Panel Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot SX60 HS Back Panel Replacement: stap 3, afbeelding 2 van 2
      • Use the Phillips #00 screwdriver to remove the 4mm #00 screw located on the bottom left of the device.
      • Use the Phillips #00 screwdriver to remove the 5mm #00 screw located on the bottom center of the device.
      • Use the Phillips #00 screwdriver to remove the 7mm #00 screw on the right top corner of the camera, just above the media ports.
      • Use the Phillips #00 screwdriver to remove the two 5mm #00 screws located on the right side, under the media port dust cover.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot SX60 HS Back Panel Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot SX60 HS Back Panel Replacement: stap 4, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Ensure the LCD screen is swung fully to the left before taking off the back panel.
      • Use the iFixit opening tool to pry off the back panel.
      • Don't completely pull off the back panel because there is still a ribbon attached.
      • Use the black spudger to unclip the ribbon located behind the battery compartment. Then remove it using the nylon tipped tweezers.
      • Once the ribbon is unplugged, remove the back panel from the camera body.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 1,173
