Ga door naar hoofdinhoud
Canon PowerShot SX530 HS Display Replacement
Wat je nodig hebt
  1. Canon PowerShot SX530 HS  Display Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip the camera upside down to find the battery compartment (marked CARD/ BATT. OPEN).
    • Press into the grooves of the battery door and slide the panel in the direction of the arrow.
    Vraag FixBot
    Voeg opmerking toe
  2. Canon PowerShot SX530 HS  Display Replacement: stap 2, afbeelding 1 van 1
    • Gently press down on the orange release button found inside.
    • After pressing the release button, pull the battery out of the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Canon PowerShot SX530 HS  Display Replacement, Canon PowerShot SX530 HS Back Panel Assembly: stap 3, afbeelding 1 van 2 Canon PowerShot SX530 HS  Display Replacement, Canon PowerShot SX530 HS Back Panel Assembly: stap 3, afbeelding 2 van 2
    • Flip over the camera.
    • Use a Phillips PH000 to remove the two 4mm screws near the center of the camera.
    • Use a Phillips PH000 to remove the two 6mm screws on the ends of the camera.
    Vraag FixBot
    Voeg opmerking toe
  4. Canon PowerShot SX530 HS  Display Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot SX530 HS  Display Replacement: stap 4, afbeelding 2 van 2
    • Locate the left side of the camera.
    • Use a Philips PH000 to remove the two 6mm screws.
    Vraag FixBot
    Voeg opmerking toe
  5. Canon PowerShot SX530 HS  Display Replacement: stap 5, afbeelding 1 van 2 Canon PowerShot SX530 HS  Display Replacement: stap 5, afbeelding 2 van 2
    • Rotate the camera to the side with the removable cover containing the HDMI and mini USB ports.
    • Use the Phillips PH000 to remove the 7mm screw located next to the HDMI port. This screw has red loctite.
    • Use the Phillips PH000 to remove the 4mm screw near the USB port.
    • Use the Phillips PH000 to remove the 7.4mm screw near the USB port.
    Vraag FixBot
    Voeg opmerking toe
  6. Canon PowerShot SX530 HS  Display Replacement: stap 6, afbeelding 1 van 3 Canon PowerShot SX530 HS  Display Replacement: stap 6, afbeelding 2 van 3 Canon PowerShot SX530 HS  Display Replacement: stap 6, afbeelding 3 van 3
    • Rotate the camera to locate the side with the LCD screen.
    • Use a Phillips PH000 to remove the two 6mm screws above the LCD screen.
    • Once the screws are out the back panel, it is ready to be taken off. Grip the backside of the camera and pull it away evenly on every side. The backside must come off straight from the front.
    Vraag FixBot
    Voeg opmerking toe
  7. Canon PowerShot SX530 HS  Display Replacement, Internal Button Sensor Plate: stap 7, afbeelding 1 van 2 Canon PowerShot SX530 HS  Display Replacement, Internal Button Sensor Plate: stap 7, afbeelding 2 van 2
    • Locate the Internal Button Sensor Plate. This is the white and silver plate to the right of the LCD Display.
    • Use a Phillips PH000 to remove the two 3mm screws on the panel.
    • Use a Phillips PH000 to remove the 3mm screw connected to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  8. Canon PowerShot SX530 HS  Display Replacement: stap 8, afbeelding 1 van 2 Canon PowerShot SX530 HS  Display Replacement: stap 8, afbeelding 2 van 2
    • Peel off the plate. Be careful, as the plate is connected to the motherboard underneath by a ribbon.
    • Use a plastic opening tool to unlock the ribbon tape.
    • Remove the ribbon tape from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  9. Canon PowerShot SX530 HS  Display Replacement, LCD Display: stap 9, afbeelding 1 van 2 Canon PowerShot SX530 HS  Display Replacement, LCD Display: stap 9, afbeelding 2 van 2
    • Locate the Display screen in the center of the camera.
    • Use a plastic opening tool to pry off the LCD screen. Start on the bottom left corner—this is the furthest away from the ribbon holding it down on the right side.
    • The adhesive holding down the display should be strong enough to put the display back on.
    Vraag FixBot
    Voeg opmerking toe
  10. Canon PowerShot SX530 HS  Display Replacement: stap 10, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
Conclusie
4 andere personen hebben deze handleiding voltooid.
Xavier Patrick
488 Reputatie
3 handleidingen geschreven
USF Tampa, Team 16-4, Blackwell Spring 2017 Lid van USF Tampa, Team 16-4, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G4
4 Leden
9 handleidingen geschreven
1Gids Commentaar
What LCD screen u used
Frank Spencer - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 37
Altijd: 3,213
