Ga door naar hoofdinhoud
Canon PowerShot SD450 Flash Bulb
Wat je nodig hebt
    1. Canon PowerShot SD450 Flash Bulb, Casing: stap 1, afbeelding 1 van 1
      • Remove the battery and SD Card from their slots. Leaving these in could cause the battery to ground and ruin the electronics.
      • Unscrew the six screws on the casing. Two are on the bottom as pictured; two more are on each side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SD450 Flash Bulb: stap 2, afbeelding 1 van 1
      • Pull the lanyard mount off of the camera using a spudger or your fingers.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SD450 Flash Bulb: stap 3, afbeelding 1 van 2 Canon PowerShot SD450 Flash Bulb: stap 3, afbeelding 2 van 2
      • Find the line that separates the casing into its two halves. Hold each half separately, and gently pull apart.
      • Note that there is a small metal clip holding the two halves together. It might help to press down on the back half (indicated) while pulling upward slightly on the front half.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot SD450 Flash Bulb: stap 4, afbeelding 1 van 1
      • Take hold of the inside of the camera, and gently pull away from the back casing.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot SD450 Flash Bulb: stap 5, afbeelding 1 van 1
      • Remove the square, clear, rubber protector from the front of the logic board. This is not necessary to remove, but can easily fall off and get lost during later steps.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon PowerShot SD450 Flash Bulb: stap 6, afbeelding 1 van 1
      • When you reassemble the camera, make sure the switch on the casing matches the position of the switch on the camera internals.
      • The black viewfinder padding can easily fall off the casing. Make sure you don't lose it when moving around parts.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot SD450 Flash Bulb, Motherboard: stap 7, afbeelding 1 van 1
      • Remove the LCD cable by gently prying the hinge open with a spudger or your finger. The cable should easily slide out.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SD450 Flash Bulb: stap 8, afbeelding 1 van 1
      • Lift up the metallic-colored clip with the spudger to remove the shutter panel.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SD450 Flash Bulb: stap 9, afbeelding 1 van 1
      • Remove the shutter panel with the spudger, now that the clip is released.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot SD450 Flash Bulb: stap 10, afbeelding 1 van 1
      • Use the spudger or your finger to release the orange ribbon from the logic board.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot SD450 Flash Bulb: stap 11, afbeelding 1 van 1
      • Pull the ribbon out of the socket using the spudger or your finger.
      • Disconnect the two other ribbons from the logic board in the same fashion.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon PowerShot SD450 Flash Bulb: stap 12, afbeelding 1 van 1
      • Lift up the large green flap by using the spudger to pry up top right yellow edge.
      Vraag FixBot
      Voeg opmerking toe
    7. Canon PowerShot SD450 Flash Bulb: stap 13, afbeelding 1 van 1
      • Pull the flap back with the spudger so that the logic board is exposed.
      Vraag FixBot
      Voeg opmerking toe
    8. Canon PowerShot SD450 Flash Bulb: stap 14, afbeelding 1 van 1
      • Use the screwdriver to remove the three screws on the logic board. Take note that the bottom right screw is shorter than the other two.
      Vraag FixBot
      Voeg opmerking toe
    9. Canon PowerShot SD450 Flash Bulb: stap 15, afbeelding 1 van 1
      • Use the spudger to carefully remove the logic board from behind.
      Vraag FixBot
      Voeg opmerking toe
    10. Canon PowerShot SD450 Flash Bulb: stap 16, afbeelding 1 van 1
      • Remove the detached logic board from the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot SD450 Flash Bulb, Flash Bulb: stap 17, afbeelding 1 van 1
      • Remove the side screw holding the flash bulb.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot SD450 Flash Bulb: stap 18, afbeelding 1 van 1
      • Remove the orange ribbon from below the lens.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot SD450 Flash Bulb: stap 19, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Grasp the plug that yellow and black wires are attached to, and gently remove. Tweezers are very helpful here.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot SD450 Flash Bulb: stap 20, afbeelding 1 van 3 Canon PowerShot SD450 Flash Bulb: stap 20, afbeelding 2 van 3 Canon PowerShot SD450 Flash Bulb: stap 20, afbeelding 3 van 3
      • Note that there is a capacitor in the flash bulb assembly, under the small circuit board. Do not touch the two metal terminals, as the capacitor may discharge. Damage and personal injury may result.
      • Use the spudger to carefully lift the flash bulb out.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Sean Whelan
19 Reputatie
1 Handleiding geschreven
Cal Poly, Team 25-85, Amido Spring 2010 Lid van Cal Poly, Team 25-85, Amido Spring 2010
CPSU-AMIDO-S10S25G85
4 Leden
5 handleidingen geschreven
1Gids Commentaar
excellent a+!
Michelle - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 35
Altijd: 4,670
