Ga door naar hoofdinhoud
Canon PowerShot G11 Front Cover Replacement
Wat je nodig hebt
    1. Canon PowerShot G11 Front Cover Replacement, Rear Cover: stap 1, afbeelding 1 van 1
      • Remove the three screws on the bottom of the camera using the 00 sized phillips head screw driver.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot G11 Front Cover Replacement: stap 2, afbeelding 1 van 1
      • Remove the four screws on the left side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot G11 Front Cover Replacement: stap 3, afbeelding 1 van 1
      • Remove the screw on the right side of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot G11 Front Cover Replacement: stap 4, afbeelding 1 van 1
      • Open up the HDMI port on the right side of the camera. Then remove the screw in the HDMI port.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot G11 Front Cover Replacement: stap 5, afbeelding 1 van 1
      • Remove the screw to the right of the view finder on the rear of the camera.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon PowerShot G11 Front Cover Replacement: stap 6, afbeelding 1 van 1
      • Use the spudger to crack open the case.
      Vraag FixBot
      Voeg opmerking toe
    7. Canon PowerShot G11 Front Cover Replacement: stap 7, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • The rear case is still attached to the camera with a ribbon cable. The socket has a flip up lid that must be flipped up before the cable can be removed. Use the tweezers to flip the cable attachment up.
      Vraag FixBot
      Voeg opmerking toe
    8. Canon PowerShot G11 Front Cover Replacement: stap 8, afbeelding 1 van 1
      • The rear cover is now unattached from the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot G11 Front Cover Replacement, Front Cover: stap 9, afbeelding 1 van 2 Canon PowerShot G11 Front Cover Replacement, Front Cover: stap 9, afbeelding 2 van 2
      • Push the button on the bottom right of the camera and then remove the plastic surrounding the lens.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot G11 Front Cover Replacement: stap 10, afbeelding 1 van 1
      • Use the spudger to pop off front case.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot G11 Front Cover Replacement: stap 11, afbeelding 1 van 1
      • Pull the loosened cover off and you are finished.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Dustin Brinegar
715 Reputatie
4 handleidingen geschreven
USF Tampa, Team 5-6, Brown Winter 2015 Lid van USF Tampa, Team 5-6, Brown Winter 2015
USFT-BROWN-W15S5G6
3 Leden
16 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 35
Altijd: 2,890
