Ga door naar hoofdinhoud
Canon PowerShot A75 Batteries Replacement
    1. Canon PowerShot A75 Batteries Replacement, Batteries: stap 1, afbeelding 1 van 1
      • Turn the camera over and locate the "BATT OPEN" sliding switch.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A75 Batteries Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot A75 Batteries Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot A75 Batteries Replacement: stap 2, afbeelding 3 van 3
      • Slide the switch to the right.
      • The battery cover should slide down and spring open.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A75 Batteries Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot A75 Batteries Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot A75 Batteries Replacement: stap 3, afbeelding 3 van 3
      • Remove the 4 AA batteries.
      • Watch for the orientation of the batteries as they slide out.
      • The battery orientation is shown under the battery flap itself and on a sticker next to the battery flap.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Put in fresh batteries. Gently shut the flap and slide it forward until you hear a click.
Henry Braden Fisk
63 Reputatie
1 Handleiding geschreven
Cal Poly, Team 17-30, Amido Spring 2012 Lid van Cal Poly, Team 17-30, Amido Spring 2012
CPSU-AMIDO-S12S17G30
5 Leden
60 handleidingen geschreven
4Gids Commentaar
Hi, there is a problem with my Powershot a75. Whenever I switch it on, it just says change the batteries even though they are either new, or fully charged. Thanks
Harry collier - Antwoord Deel
had same trouble i fix it buy pressing the print button on back next to the disp button it should work then
hot5 - Antwoord Deel
Probably you have change backup battery which is rechargeable and not easy to change. It is close to chargeable outlet.
Maganbhai Patel - Antwoord Deel
Bonjour j'ai un petit problème avec mon appareil photo. J'essaye de l'ouvrir avec le bouton mais elle ne s'allume pas et les supports de piles ont rouillé et la carte orange à été un peu touché par la rouillé aussi. Comment pourrais-je le faire fonctionner?
Leyla minal - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 64
Altijd: 3,018
