Wat je nodig hebt
Slide the tab on the battery door while pushing the battery door away from you. The battery door should pop open.
Insert AA batteries according to the diagram printed on the camera.
Close the battery door.
Unscrew the three Phillips #00 1.6x3mm screws on the side.
Lift loose panel from the case.
Unscrew the two Phillips #00 1.6x3mm screws that were previously hidden beneath the panel.
Open the battery door.
Unscrew the four Phillips #00 1.6x3mm screws in the battery compartment.
Lift the terminal cover on the side of the camera.
Unscrew the three Phillips #00 1.6x3mm screws beneath the terminal cover.
Slide the memory card cover down.
Unscrew the Phillips #00 1.6x3mm screw beneath the memory card cover.
1Gids Commentaar
Ottima spiegazione: é tutto facile quando la spiegazione é semplice ed univoca. Ma redigere istruzioni semplici é un'arte che non tutti possiedono.
