Ga door naar hoofdinhoud
Canon PowerShot A550 LCD Screen Replacement
Wat je nodig hebt
    1. Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: stap 1, afbeelding 1 van 3 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: stap 1, afbeelding 2 van 3 Canon PowerShot A550 LCD Screen Replacement, Front and Back Covers: stap 1, afbeelding 3 van 3
      • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
      • There are 2 screws on the left side (when looking at the front of the camera).
      • There are 3 screws on the bottom
      • There is 1 screw on the right side
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A550 LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Turn to the bottom of the camera.
      • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A550 LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • This is what the SD card/battery compartment looks like when opened.
      • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot A550 LCD Screen Replacement: stap 4, afbeelding 1 van 2 Canon PowerShot A550 LCD Screen Replacement: stap 4, afbeelding 2 van 2
      • Gently remove the front cover away from the camera body.
      • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot A550 LCD Screen Replacement: stap 5, afbeelding 1 van 1
      • The camera should look like this once the front cover is removed.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon PowerShot A550 LCD Screen Replacement: stap 6, afbeelding 1 van 3 Canon PowerShot A550 LCD Screen Replacement: stap 6, afbeelding 2 van 3 Canon PowerShot A550 LCD Screen Replacement: stap 6, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      • Start from the battery compartment and remove the back cover.
      • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
      • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
      Vraag FixBot
      Voeg opmerking toe
    7. Canon PowerShot A550 LCD Screen Replacement: stap 7, afbeelding 1 van 1
      • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot A550 LCD Screen Replacement, LCD Screen: stap 8, afbeelding 1 van 1
      • Use a #00 phillips head screwdriver to remove 2 3.34mm phillips screws holding the LCD screen in place.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A550 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot A550 LCD Screen Replacement: stap 9, afbeelding 2 van 2
      • Use an iPod Opening Tool to lift the brown portion of the connector to unlock it.
      • Slide the data cable out of the connector.
      • Caution: Do not force the data cable out of the connector. It may rip!
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A550 LCD Screen Replacement: stap 10, afbeelding 1 van 1
      • The LCD screen can now be be removed to be fixed/replaced.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Precilla Tang
207 Reputatie
2 handleidingen geschreven
Cal Poly, Team 8-6, Regan Spring 2011 Lid van Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Leden
22 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 51
Altijd: 4,236
