Inleiding
If your camera keeps showing you an "SD card error"message, but the SD card in use is the correct type and is uncorrupted, your SD card reader may be in need of replacement. After removing the back cover and the LCD screen, you will be able to replace the SD card reader yourself.
Wat je nodig hebt
Turn off the camera.
Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
Turn the camera to view the back.
Remove the one (1) 3.0 mm screw on the top right corner of the screen.
