Ga door naar hoofdinhoud
Canon PowerShot A540 LCD Screen Replacement
Wat je nodig hebt
    1. Canon PowerShot A540 LCD Screen Replacement, Back Cover: stap 1, afbeelding 1 van 2 Canon PowerShot A540 LCD Screen Replacement, Back Cover: stap 1, afbeelding 2 van 2
      • Turn off the camera.
      • Turn the camera upside-down and press the tab to release the battery cover. Remove the batteries.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A540 LCD Screen Replacement: stap 2, afbeelding 1 van 1
      • Turn the camera upside down to view the "Card/Batt. Open" Cover.
      • Use a Phillips head #000 screwdriver to remove the three (3) 4.0 mm screws.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A540 LCD Screen Replacement: stap 3, afbeelding 1 van 1
      • Open "Card/Batt. Open" Cover.
      • Remove the one (1) 5.0 mm screw with the Phillips head #000 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot A540 LCD Screen Replacement: stap 4, afbeelding 1 van 1
      • Turn the camera to the right side of the LCD screen.
      • Remove the three (3) 4.0 mm screws with the Phillips head #000 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot A540 LCD Screen Replacement: stap 5, afbeelding 1 van 3 Canon PowerShot A540 LCD Screen Replacement: stap 5, afbeelding 2 van 3 Canon PowerShot A540 LCD Screen Replacement: stap 5, afbeelding 3 van 3
      • Gently remove the back cover.
      • Start at the bottom at the corner of the "Card/Batt. Open" Cover.
      • Then move onto the other edges and the top.
      • It may be tight at the top!
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot A540 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 1 van 2 Canon PowerShot A540 LCD Screen Replacement, LCD Screen: stap 6, afbeelding 2 van 2
      • Turn the camera to view the back.
      • Remove the one (1) 3.0 mm screw on the top right corner of the screen.
      • There is a small metal bar that rests on this frame. Keep it with the screws that have been removed from the camera.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A540 LCD Screen Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot A540 LCD Screen Replacement: stap 7, afbeelding 2 van 2
      Gereedschap gebruikt in deze stap:
      • Lift the LCD Screen off of the back to view the attached ribbon cables.
      • Use tweezers to flip the black bar up.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A540 LCD Screen Replacement: stap 8, afbeelding 1 van 3 Canon PowerShot A540 LCD Screen Replacement: stap 8, afbeelding 2 van 3 Canon PowerShot A540 LCD Screen Replacement: stap 8, afbeelding 3 van 3
      • Gently pull the big ribbon out.
      • Gently pull the small ribbon out.
      • The small ribbon does not have a bar like the big ribbon.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot A540 LCD Screen Replacement: stap 9, afbeelding 1 van 2 Canon PowerShot A540 LCD Screen Replacement: stap 9, afbeelding 2 van 2
      • Use tweezers at the top left of the LCD Screen to wedge the top left of the Outer Frame loose.
      • Use your thumb to hold the Outer Frame open.
      • Use the tweezers at the top right of the LCD Screen to wedge the top right of the Outer Frame loose.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot A540 LCD Screen Replacement: stap 10, afbeelding 1 van 2 Canon PowerShot A540 LCD Screen Replacement: stap 10, afbeelding 2 van 2
      • Slide the LCD Screen out from the Outer Frame.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Carley Fuller
434 Reputatie
3 handleidingen geschreven
Baylor, Team 7-12, Williams Spring 2015 Lid van Baylor, Team 7-12, Williams Spring 2015
BU-WILLIAMS-S15S7G12
3 Leden
20 handleidingen geschreven
1Gids Commentaar
I wish to purchase a new screen. Where? I feel capable of repair per these instructions and a u tube video.
Geo Schou - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 37
Altijd: 1,585
