Ga door naar hoofdinhoud
Canon PowerShot A480 Battery Replacement
Wat je nodig hebt
    1. Canon PowerShot A480 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Canon PowerShot A480 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Canon PowerShot A480 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
      • Make sure to fully power off the camera before starting the replacement process.
      • Locate the battery door at the underside of your camera and orient it so that the door points to the right.
      • Gently apply downward pressure to the right edge of the door and slide to the right.
      • Once you hear an audible click, lift up the bay door in the opposite direction till the batteries are fully exposed.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A480 Battery Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot A480 Battery Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot A480 Battery Replacement: stap 2, afbeelding 3 van 3
      • Ensure that the contacts for the batteries are free of any corrosion.
      • Gently tip the body of the camera towards your body to slide the batteries out.
      • Slide the batteries out enough to where you are able to grasp both of them for removal.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
After obtaining two replacement AA batteries. To reassemble your device, follow these instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Kenneth Robertson
309 Reputatie
1 Handleiding geschreven
UW Tacoma, Team S1-G5, Cardinal Spring 2019 Lid van UW Tacoma, Team S1-G5, Cardinal Spring 2019
UWT-CARDINAL-S19S1G5
4 Leden
4 handleidingen geschreven
1Gids Commentaar
Will the normal AA batteries work?
Viswanath harikumar - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 109
Altijd: 5,551
