Ga door naar hoofdinhoud
Canon PowerShot A2500 LCD Display Replacement
Wat je nodig hebt
    1. Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: stap 1, afbeelding 1 van 2 Canon PowerShot A2500 LCD Display Replacement, Body Casing and Faceplate: stap 1, afbeelding 2 van 2
      • Remove the knot holding the wrist lanyard onto the camera
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A2500 LCD Display Replacement: stap 2, afbeelding 1 van 1
      • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
      • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
      • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A2500 LCD Display Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot A2500 LCD Display Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot A2500 LCD Display Replacement: stap 3, afbeelding 3 van 3
      • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot A2500 LCD Display Replacement: stap 4, afbeelding 1 van 3 Canon PowerShot A2500 LCD Display Replacement: stap 4, afbeelding 2 van 3 Canon PowerShot A2500 LCD Display Replacement: stap 4, afbeelding 3 van 3
      • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
      • Be careful not to bend the plastic casing to much, as it will crack.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot A2500 LCD Display Replacement, Buttons: stap 5, afbeelding 1 van 1
      • Remove the single philips #00 screw on the button pad which are 2.2mm long. This screw is circled in red in the guide image.
      • Next, remove the two 2.4mm long screws located in between the LCD screen and the touch pad. These screws will require a Phillips #00 screwdriver.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A2500 LCD Display Replacement: stap 6, afbeelding 1 van 2 Canon PowerShot A2500 LCD Display Replacement: stap 6, afbeelding 2 van 2
      • Pull the two clips off located near the power button
      • The clips are easily broken, use care while disconnecting these clips.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A2500 LCD Display Replacement: stap 7, afbeelding 1 van 3 Canon PowerShot A2500 LCD Display Replacement: stap 7, afbeelding 2 van 3 Canon PowerShot A2500 LCD Display Replacement: stap 7, afbeelding 3 van 3
      • Remove the circuit ribbon connecting the flash to the camera in order to proceed to the next instruction.
      • Carefully pull out the circuit ribbon from the camera which should be the last piece holding the button pad onto the camera.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot A2500 LCD Display Replacement, LCD Display: stap 8, afbeelding 1 van 1
      • Lift the tab at the end of the ribbon
      • Disconnect the ribbon from the circuitboard
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Victoria Winters
307 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-4, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-4, Duarte Spring 2015
UMASSD-DUARTE-S15S3G4
4 Leden
12 handleidingen geschreven
2Gids Commentaar
There seams to be a step missing on step 6 . As there is a screw that has to be removed covered to the left of button on top of camera.
Jack Banks - Antwoord Deel
There seams to be a step missing on step 6...
Vinicius Maia - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 50
Altijd: 2,024
