Ga door naar hoofdinhoud
Canon PowerShot A2500 Flash Component Replacement
Wat je nodig hebt
  1. Canon PowerShot A2500 Flash Component Replacement, Body Casing and Faceplate: stap 1, afbeelding 1 van 2 Canon PowerShot A2500 Flash Component Replacement, Body Casing and Faceplate: stap 1, afbeelding 2 van 2
    • Remove the knot holding the wrist lanyard onto the camera
    Vraag FixBot
    Voeg opmerking toe
  2. Canon PowerShot A2500 Flash Component Replacement: stap 2, afbeelding 1 van 1
    • Open the latch at the bottom corner of the device to reveal the battery and SD card housing.
    • There is an orange latch holding the battery in place which must be pushed back in order to free the battery.
    • Once the battery is removed push the SD card and this will activate a spring ejecting the card from the camera.
    Vraag FixBot
    Voeg opmerking toe
  3. Canon PowerShot A2500 Flash Component Replacement: stap 3, afbeelding 1 van 3 Canon PowerShot A2500 Flash Component Replacement: stap 3, afbeelding 2 van 3 Canon PowerShot A2500 Flash Component Replacement: stap 3, afbeelding 3 van 3
    • Remove the 6 Phillips #00 exterior screws from the camera. Two are located on the bottom and two are located on either side as shown. Notice that one of the screws is under the AV Out Digital flap on the side. All exterior screws should be 2.4mm in length
    Vraag FixBot
    Voeg opmerking toe
  4. Canon PowerShot A2500 Flash Component Replacement: stap 4, afbeelding 1 van 3 Canon PowerShot A2500 Flash Component Replacement: stap 4, afbeelding 2 van 3 Canon PowerShot A2500 Flash Component Replacement: stap 4, afbeelding 3 van 3
    • Pry apart the camera casing using the plastic opening tool tool provided. Once the casing has begun to separate pull the two sides apart with your hands.
    • Be careful not to bend the plastic casing to much, as it will crack.
    Vraag FixBot
    Voeg opmerking toe
  5. Canon PowerShot A2500 Flash Component Replacement, Flash Component: stap 5, afbeelding 1 van 1
    • Lift LCD Display using the plastic opening tool to access the screws.
    Vraag FixBot
    Voeg opmerking toe
  6. Canon PowerShot A2500 Flash Component Replacement: stap 6, afbeelding 1 van 1
    • Remove top left phillips #00 screw under LCD display
    • The screw should be 3.6mm long and the face of the screw should have a 2.4mm diameter
    Vraag FixBot
    Voeg opmerking toe
  7. Canon PowerShot A2500 Flash Component Replacement: stap 7, afbeelding 1 van 2 Canon PowerShot A2500 Flash Component Replacement: stap 7, afbeelding 2 van 2
    • Once the screw is removed lift small brown tab and carefully remove the ribbon tape connecting the flash component to the camera
    • Now the flash component is completely separated from the computer and ready to be replaced or repaired
    • Be sure to have the battery removed before disconnecting this tab. This will ensure that there is no possible charge remaining in the capacitor.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
James Hickey
393 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-4, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-4, Duarte Spring 2015
UMASSD-DUARTE-S15S3G4
4 Leden
12 handleidingen geschreven
1Gids Commentaar
Great tutorial, but I am left with one problem - where can I buy a flash component? Just can’t seem to find any on the internet.
Jonathan, UK
Jonathan Mitchell - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 26
Altijd: 1,048
