Ga door naar hoofdinhoud
Canon PowerShot A2300 Flash Assembly Replacement
Wat je nodig hebt
    1. Canon PowerShot A2300 Flash Assembly Replacement, Front Cover: stap 1, afbeelding 1 van 1
      • Open the A/V Out Digital port cover on the function button side to reveal a screw.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A2300 Flash Assembly Replacement: stap 2, afbeelding 1 van 3 Canon PowerShot A2300 Flash Assembly Replacement: stap 2, afbeelding 2 van 3 Canon PowerShot A2300 Flash Assembly Replacement: stap 2, afbeelding 3 van 3
      • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
      • Screws are small and very easily lost.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A2300 Flash Assembly Replacement: stap 3, afbeelding 1 van 2 Canon PowerShot A2300 Flash Assembly Replacement: stap 3, afbeelding 2 van 2
      • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
      • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot A2300 Flash Assembly Replacement: stap 4, afbeelding 1 van 1
      • Gently lift the bottom of the front cover to roughly a 30 degree angle.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot A2300 Flash Assembly Replacement: stap 5, afbeelding 1 van 1
      • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot A2300 Flash Assembly Replacement, Back Cover: stap 6, afbeelding 1 van 1
      • Hold the camera in your hands with both thumbs on the screen with the screen faced up.
      • Keep close to the table top in case the camera falls out of your hands.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A2300 Flash Assembly Replacement: stap 7, afbeelding 1 van 1
      • Pull the the bottom left corner of the cover up about an inch to the point shown in the picture.
      • Do not completely remove the back cover by pulling on the side as shown. The cover is still attached on the top of the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A2300 Flash Assembly Replacement: stap 8, afbeelding 1 van 1
      • Pry the top off by sliding the spudger under the On/Off button.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot A2300 Flash Assembly Replacement: stap 9, afbeelding 1 van 1
      • Slide the cover to the right and off the camera.
      • Gently pry using the spudger on the right side if necessary.
      • The A/V OUT DIGITAL cover will sometimes become loose and disconnect from the cover
      Vraag FixBot
      Voeg opmerking toe
    1. Canon PowerShot A2300 Flash Assembly Replacement, Flash Assembly: stap 10, afbeelding 1 van 1
      • Raise the screen by wedging the spudger between the bottom of the screen and the mount hole.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon PowerShot A2300 Flash Assembly Replacement: stap 11, afbeelding 1 van 1
      • Remove the metal sheet that is under the screen.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon PowerShot A2300 Flash Assembly Replacement: stap 12, afbeelding 1 van 1
      • Remove the top left screw on the metal sheet that is behind the screen.
      • This screw connects the flash to the metal sheet.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon PowerShot A2300 Flash Assembly Replacement: stap 13, afbeelding 1 van 1
      Gereedschap gebruikt in deze stap:
      • Use one side of the tweezers to raise the orange retaining flap on the zero insertion force (ZIF) connector to a vertical position.
      Vraag FixBot
      Voeg opmerking toe
    5. Canon PowerShot A2300 Flash Assembly Replacement: stap 14, afbeelding 1 van 1
      • Gently pull the orange ribbon cable out of the ZIF connector using the tweezers.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon PowerShot A2300 Flash Assembly Replacement: stap 15, afbeelding 1 van 2 Canon PowerShot A2300 Flash Assembly Replacement: stap 15, afbeelding 2 van 2
      • Remove the flash by gently rotating slightly back and forth and pulling up.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nathan McMillan
405 Reputatie
2 handleidingen geschreven
Baylor, Team 7-14, Williams Spring 2015 Lid van Baylor, Team 7-14, Williams Spring 2015
BU-WILLIAMS-S15S7G14
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 65
Altijd: 2,587
